Tripometer Randomly Resetting and other probs
Old 09-14-2004, 10:45 PM
Z28Bama's Avatar
Default Tripometer Randomly Resetting and other probs
1) My tripometer has reset back to 0.0 by itself 3X within the last two weeks. The ODO seems to be fine though.
2) I have rich Bank 1/2 codes, and a bad pinging (detonation) at 5K+, related?
Thanks
Old 09-14-2004, 10:50 PM
horist's Avatar
what year car? this was an issue w/the 99s I believe
https://ls1tech.com/forums/pcm-diagnostics-tuning/153897-odometer-resets-everytime-i-start.html
though w/only 5k miles i'd guess it's an 02? MAYBE an 01? if that's the case bring it to the dealership... make GM pay out some of the money they already charged you for the warranty.. and help out a mechanic
Old 09-14-2004, 10:54 PM
horist's Avatar
ok did a lil reasearch and found this post:
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/203044-new-forum-ls1-s.html
so you've gotta 99
do a search for "trip reset" and you'll find that you're not alone ... seems to be a common issue w/99s ,
https://ls1tech.com/forums/showthread.php?t=153897
TSB: 99-08-49-009 trip odometer-automaticaly resets to zero
sounds like the fix is the gauge cluster needs to be replaced... dunno if this type of thing would be warranteed since the car is 5-6 years old
I interpretted the 5k as miles and not RPM ... my bad
what O2 codes are you setting?
Old 09-14-2004, 11:06 PM
Z28Bama's Avatar
I think the codes were 0172 and 0176..........can't remember
Old 09-14-2004, 11:09 PM
Z28Bama's Avatar
So are the dealer's required to fix this since it is a TSB?
Old 09-14-2004, 11:13 PM
horist's Avatar
P0172: Fuel Trim System Rich Bank 1
P0176: Fuel Composition Sensor Circuit
ok... 176 I have never seen before...
for the P0172 ... i'd check for vacuum leaks ... spray a flammable spray (brake cleaner... just make sure it says "warning flammable") along the intake manifold... on the drivers side ... listen for changes in idle characteristics ... if it changes you've gotta vacuum leak... that can cause high LTRIMs (+25%)
do you have anyway of logging/scanning your car? (also please update your signature and from location ... it helps for knowing about your car and you ... sometimes people that are local to you will help you out)
if u can... verify the 176 code... Only reference to that code on the entire site is a DTC list that 2000 Camaro SS posted back in April 2002 (https://ls1tech.com/forums/showthrea...ighlight=P0176)
slow's Avatar
its not a recall, so its not required to be fixed, just something that the dealers need to be aware of for the car in warranty that have problems, and the proper solution.
Ryan
Old 09-14-2004, 11:22 PM
Z28Bama's Avatar
It was the same code as the 0172, but for bank 2.........vacuum leak?
So with the TSB, I am screwed? And have to pay out of pocket?
To be honest, this car has giving me HELL since I got it a month ago
1) Rear-end replaced
2) Error codes
3) running a second slow in the 1/4
4) now this ODO crap........come on GM!!!!!!!!!!!!!!!
Old 09-14-2004, 11:34 PM
horist's Avatar
i'd check for a vacuum leak.... if both sides are getting it... it could be a leak pre Intake manifold...
rear replace : our 10 bolt rears are weak ... but to have to replace right after buying
a second slower? whatya running?
Gotta figure out what's wrong first.. then fix it.. then run it
Old 09-14-2004, 11:56 PM
Z28Bama's Avatar
BTW, I am from Central IL, just in AL due to USAF Thanks for the help!!!!
Old 09-16-2004, 09:37 AM
smokinHawk's Avatar
strange mine is a 99 and has the same problem.
mine started doing that, then i replaced the battery and it went awy. i switched to a dynabatt and it came back is it the gauge or the battery.
Old 09-16-2004, 10:28 AM
slow's Avatar
its the cluster that goes bad, but the problem is more noticable with a low battery.
Ryan
