Help with AFR
Old 09-30-2004, 10:56 PM
JimMueller's Avatar
Question Help with AFR
My AFR from my last dyno is practically a sine wave above 5000RPM.
I'm looking for the AFR to be about 12.6-12.7 on the street, so I guess I need to tweak the reported AFR's to account for the road load being higher than a dynojet? IIRC, road load is .2-.3 higher than dynojet load, so I'd want to alter these numbers to reflect 12.4-12.5 on a dynojet? Are these values changing too rapidly or should I be looking elsewhere?
Code:
Current PExRPM
0       400     800     1200    1600    2000    2400    2800    3200    3600    4000    4400    4800    5200    5600    6000    6400    6800    7200
1.1172	1.1172	1.1172	1.1172	1.1172	1.1172	1.0872	1.1172	1.1143	1.0988	1.0872	1.0833	1.0950	1.0882	1.0620	1.0998	1.0543	1.0717	1.0717
Code:
Proposed PExRPM
1.169	1.169	1.169	1.169	1.169	1.169	1.136	1.161	1.156	1.147	1.132	1.111	1.115	1.090	1.049	1.108	1.037	1.029	1.029
Code:
RPM     AFR
2700	13.09
2800	13.01
2900	12.94
3000	12.94
3100	12.96
3200	12.99
3300	13.01
3400	13
3500	13.04
3600	13.05
3700	13.12
3800	13.17
3900	13.11
4000	13.01
4100	13.02
4200	12.98
4300	12.89
4400	12.86
4500	12.82
4600	12.81
4700	12.83
4800	12.75
4900	12.68
5000	12.66
5100	12.7
5200	12.52
5300	12.38
5400	12.3
5500	12.31
5600	12.33
5700	12.39
5800	12.49
5900	12.61
6000	12.71
6100	12.52
6200	12.38
6300	12.77
6400	12.14
6500	11.96
6600	11.94
6700	12.03
6800	12.11
6900	11.72
Old 09-30-2004, 11:14 PM
Moderator
jimmyblue's Avatar
Those PE table numbers are below normal (1.15 = 12.8:1
for the actuals you're getting. So something else is adding
enrichment (like an air or fuel metering error term). You want
to take away more from the top.
It looks like 1.09 is your number, why not try that as a flat
line value from 2400 on up and get another read? There's a
strange lump at 4800 too.
Old 10-01-2004, 08:08 AM
Moderator
JNorris's Avatar
Are you running the stock 28lb injectors?
Old 10-01-2004, 02:27 PM
JimMueller's Avatar
Yes, stock injectors.
Jimmy - can you elaborate on what could be causing additional enrichment?
Old 10-01-2004, 02:33 PM
Moderator
jimmyblue's Avatar
Presuming your Open Loop Fuel/Air table is some lower
value than the PE table, that would leave only the PE
adders/multiplers (IAT, ECT) or some sensor / table
scaling error, or residual trim from positive LTFTs.
Or COT but I don't see the abrupt onset that usually
gives that one away.
If you see the Fuel-Air Multiplier (FAM) PID coming up
with the PE table value then it has to be sensors /
tables biased rich. If you see FAM that is higher than
the PE value then it's adders or trims meddling.
Old 10-01-2004, 02:50 PM
deezel's Avatar
jimmyblue knows his stuff.
Set your O/L FAM to around 1.08 in the operating range. Then set your PE to say 1.10 flat from 2400+ and do another dyno pull. If the AFR is still all over the place, then one of your fueling tables is off or one of your sensors is off.
Edit: saw the comment about stock injectors. You are probably pushing the limits of those. What duty cycle are they running? Static injectors could explain fluctuating AFR.
Old 10-01-2004, 03:18 PM
Moderator
JNorris's Avatar
Jimmy –
So you are saying that the displayed value of the Commanded AFR PID will change depending on what fueling table (PE vs RPM or Open Loop) is being used?
On my 98 that value is always the value that is based on the Open Loop table entry. In my case that is 13:1. The stock PE vs RPM value was calculated to 11.9:1.
***EDIT*** I was wrong about the above. My Commanded WOT AFR DOES follow the PE vs RPM table. Even though 12.9 might be commanded my WB shows 11.9-12.1.
Jim-
My 98 was having the same WOT AFR issues that you are having. I ended up setting the PE vs RPM value to 1.062. This does calculate to 14.737/1.062=13.87:1 but my wide band O2 shows a consistent 12.6:1.
John
Old 10-01-2004, 09:46 PM
JimMueller's Avatar
My OLFA table appears to be stock. How do I determine the operating range you're referring to?
Also, I thought the big tuners said the 98 injectors were good to ~450rwhp? Do injectors grow 'tired' after a long life?
Code:
OLFA table
1.670	1.483	1.329	1.270	1.214	1.138	1.060	1.043	1.080	1.070	1.050	1.030	1.020	1.000	1.000	1.000	1.000	1.000	1.000
1.623	1.483	1.329	1.270	1.214	1.145	1.065	1.046	1.080	1.070	1.060	1.040	1.030	1.013	1.013	1.013	1.013	1.013	1.013
1.623	1.499	1.334	1.270	1.214	1.145	1.073	1.054	1.125	1.110	1.070	1.050	1.040	1.020	1.020	1.020	1.020	1.020	1.020
1.623	1.517	1.339	1.270	1.214	1.146	1.076	1.069	1.140	1.139	1.070	1.050	1.040	1.020	1.020	1.020	1.020	1.020	1.020
1.646	1.536	1.354	1.276	1.218	1.157	1.100	1.090	1.140	1.139	1.080	1.060	1.040	1.027	1.027	1.027	1.027	1.027	1.027
1.670	1.558	1.371	1.290	1.229	1.170	1.146	1.123	1.140	1.139	1.080	1.060	1.041	1.041	1.041	1.041	1.041	1.041	1.041
1.670	1.558	1.394	1.317	1.259	1.202	1.175	1.148	1.140	1.139	1.080	1.060	1.057	1.057	1.057	1.057	1.057	1.057	1.057
1.670	1.575	1.411	1.332	1.271	1.214	1.186	1.157	1.140	1.139	1.080	1.064	1.064	1.064	1.064	1.064	1.064	1.064	1.064
1.694	1.579	1.423	1.339	1.280	1.238	1.207	1.176	1.140	1.139	1.080	1.080	1.080	1.080	1.080	1.080	1.080	1.080	1.080
1.694	1.597	1.440	1.354	1.294	1.252	1.228	1.203	1.150	1.139	1.088	1.088	1.088	1.088	1.088	1.088	1.088	1.088	1.088
1.719	1.619	1.458	1.376	1.320	1.278	1.255	1.232	1.176	1.139	1.113	1.113	1.113	1.113	1.113	1.113	1.113	1.113	1.113
1.719	1.619	1.458	1.384	1.334	1.296	1.275	1.255	1.178	1.139	1.121	1.121	1.121	1.121	1.121	1.121	1.121	1.121	1.121
1.745	1.623	1.471	1.399	1.344	1.303	1.281	1.261	1.179	1.139	1.130	1.130	1.130	1.130	1.130	1.130	1.130	1.130	1.130
Old 10-01-2004, 10:35 PM
deezel's Avatar
The WOT operating range would be the bottom right quadrant of the table (MAP>75-80kPa and RPM>2400-3000). Those 1.13's are probably overriding your PE table at some point.
I have seen mixed opinions on the injector duty cycle issue. Some say above 80%DC can cause non-uniform fueling because the injectors are basically open all the time (static). Look at it this way - the intake valve is only open for a certain percentage of the cycle of one cylinder. If the injector is open all the time, you will end up with a puddle of fuel in the intake port waiting for the valve to open. Better to have a bigger injector spraying a properly atomized jet of fuel at the proper time.
Old 10-04-2004, 11:06 PM
JimMueller's Avatar
So I want the OLFA values to be less than those in the PExRPM table so they don't get overridden...yes? Then if the AFR isn't all over the place, I can just make the adjustments in the PExRPM table and it won't go all whack on me?
