any way to turn off adaptive learning?
Old 10-06-2004, 08:45 PM
slow's Avatar
Default any way to turn off adaptive learning?
Looking to turn off the adaptive learning for some tuning.
Is there an easy way to do this with hptuners? (98, as that may make a difference)
Ryan
Old 10-06-2004, 08:48 PM
HumpinSS's Avatar
If you are referringto LTRIMS in thier 1.5 release you will be able to...
Old 10-06-2004, 08:57 PM
slow's Avatar
ok.
I've always wondering if i was missing something on the software, but guess i wasn't missing it, the software is missing it.
Ryan
Old 10-06-2004, 09:48 PM
SmokingWS6's Avatar
Referring to air/fuel or transmission? I have problems with adaptave learning of wot shift points. Its a pita to reflash my pcm everytime i want to go to the track.
Old 10-06-2004, 09:52 PM
slow's Avatar
I mainly want to do it for more control over the trims at different locations, without having the averaged longterms and different cells to deal with.
Car will be a M6, so no need to deal with the tranny stuff
Ryan
Old 11-18-2004, 10:14 PM
slow's Avatar
ttt, just wondering how this is done in version 1.5.
TIA.
Ryan
Old 11-18-2004, 10:54 PM
horist's Avatar
edit -> general -> fuel control
go to Open & Closed Loop ... you can disable LTFT .. however I would tune the car for 0 LTRIMs before going all out on it...
if the car's properly tuned it should lock to 0 every time it goes WOT (maybe even everytime it enters PE)
Old 11-19-2004, 08:36 AM
Moderator
jimmyblue's Avatar
Or raise the closed loop enable temp and see the
open loop tune for what it is. Do you want closed
loop, no learning or do you want the loop opened?
Quick Reply: any way to turn off adaptive learning?
