SLP MAF (early version) - tuning
Old 11-02-2004, 08:24 AM
2000SSNB's Avatar
Default SLP MAF (early version) - tuning
I have a SLP 85mm MAF which I purchased soon after
SLP started offering these. Without any adjustments (MAF Translator)
I get flow readings (lb/min) which are about 4...5 lb/min lower
than with the stock MAF. Typically I get a max of 38.5...40.5 lb/min
at around 5900 rpm WOT in 3rd with the stock MAF and my bolt-ons.
With the SLP the inidcated flow at the same rpm will be around 34...35lb.min,
although in actuality it should be higher than the stock MAF. I would not expect the SLP to flow much more than the stock MAF because of the
same stock TB and the same LS6 intake opening, but maybe a few %
more (the difference in cross section is 25% more for the 85 mm SLP MAF).
Should I tune the output frequency of the MAFT such that the indicated
SLP flow with EFILive is at least 38.5...40.5 lb/min at WOT and that the
light throttle ltrims are close to zero?
Gert
Old 11-02-2004, 09:20 AM
Moderator
jimmyblue's Avatar
You could just remove the resistor and use the truck MAF
table, because without that resistor, that's exactly what
it is.
Old 11-02-2004, 07:21 PM
2000SSNB's Avatar
jimmyblue,
do you mean the bulky "black" component soldered across the bars
at the end towards the inner cover? There is also a capacitor
on the other side.
Gert
Old 11-02-2004, 07:55 PM
WS6FirebirdTA00's Avatar
what year is your car? i have a 2000 and i jsut sold mine to someone with a 98, bad experience with slp for me, from now on if their name is on it i wont have it
Old 11-02-2004, 08:03 PM
Moderator
jimmyblue's Avatar
Mine ('01-'02 model) had only the 2.7K resistor wrapped
in heat-shrink. I've never heard of a capacitor on the
MAF.
Looking at the picture, though, I guess maybe you're
seeing the IAT thermistor that's in the throat of the
85mm MAFs.
Old 11-03-2004, 06:05 PM
2000SSNB's Avatar
You are right. It is not a tantalum capacitor but the IAT
thermistor - sorry,
Thanks for the clarification,
Gert
Old 11-03-2004, 11:59 PM
T/A rocker's Avatar
it is.
Seems like I read somewhere if you have a '98 model, you can't use the truck MAF table, is that true ?
Old 11-04-2004, 08:41 AM
Moderator
jimmyblue's Avatar
I think earlier years may have a MAF table that stops
earlier and you might just have to discard the higher
airflow datapoints. But, that also means the car will
have a lower point at which the airflow reading stops
making sense. On my stockish setup that is well above
my max airflow and MAF frequency. But if you have a
heavy breather this might come into play.
What is the uppermost RPM column in your MAF table?
11500? If so then you're only going to discard a couple
of right-hand cells off the truck table. Also some models
populate below 1500Hz and others don't (not that it's
very important, my A4 idles at about 2500Hz in Park).
But supposedly the electronic throttle cars can get down
that low on decel.
Old 11-04-2004, 11:33 PM
T/A rocker's Avatar
Anybody got a link or know where I can get the truck MAF table?
I saw it somewhere once, nowI can't find it !
Old 11-05-2004, 01:04 AM
SmokingWS6's Avatar
If you can't find the maf tables I think mutiplying your tables by 10 to 15% will get you in the ballpark. Perhaps Jimmyblue can chime in on this.
