disable torque mngt on a M6?
Old 02-18-2005, 12:03 PM
Magyver's Avatar
Default disable torque mngt on a M6?
TCS Retard vs RPM = 0
2nd TCS Retard vs RPM = 0
Max Torque = 639.0
Abuse Mode Test
if RPM > 6600
if speed < 0
I have no CATS so
COT enabled = False
someone on another site suggested this. I was confused b/c I didn't think an M6 had torque management.
Old 02-18-2005, 12:18 PM
horist's Avatar
I didn't think there was TM in M6 either, but there was a post on our local message board where it was brought up and INTMD8 (Speed Inc's tuner... very knowledgable person who knows his ****) brought up that M6's do indeed have some torque management
I'm guessing the code on the M6 is such that when the clutch is applied it pulls timing in anticipation of the shift
Old 02-18-2005, 03:42 PM
Magyver's Avatar
As far as TCS set to = 0 wouldn't turn off on the dash do the same thing?
Old 02-18-2005, 09:33 PM
Kenafin_02TA's Avatar
There's torque management, and traction control (TCS {ASR for the Camaro folks}). Hitting the button to turn on/off TCS/ASR has no effect on torque management. I've heard that there's some interconnection in the tables in LS1Edit between torque management and traction control..but I don't understand it well enough to know if that's true or not.
Mayver, I'm guessing those values are from your car. Do you have traction control or not? I'd like to see how those values compare across a car (one with traction control, one without) of the same transmission type. I'm got one car with traction control, and one without, but unfortunately, one's an M6, and one's an A4..so while I can compare those stock values...I won't know whether the difference is from the traction control or the tranny.
Old 02-18-2005, 11:09 PM
HumpinSS's Avatar
There are TQ management tables and then there are TCS tables. M6's pcms pull timming (anda lot of it) for regular tq management. I disabled all of them and left the tcs tables alone since they will save your *** in the rain and the snow. But the regular TQ mngmt tables were all disabled
Retard vs. Tq Reduction
Code:
0	9	13	16	19	21	23	24	26	27	29	30	32	33	34	35	36	37	38	39	40	41	42	43	44	45	46	47	48	48	49	50	50
Tq Loss vs Spark Retard
Code:
0	0.1	1	2.5	4.8	7.9	11.6	16.1	21.3	27.2	33.8	41.2	49.3	58	67.6	77.8	88.7	100
Old 02-19-2005, 07:01 AM
Magyver's Avatar
I have the ASR button. I guess for events like Road Course and AutoXing I should turn it off?
Old 02-19-2005, 11:17 PM
Nova5's Avatar
Depends. Do you want to be able to spin your tires or would you rather the car kick back the throttle at you when you spin them?
Old 02-19-2005, 11:22 PM
HumpinSS's Avatar
you are talking about two different things. The pedal being pushed back is traction control (ASR/TCS). If we intend on spinning the tires chances are we have turned asr off so the pcm wont pull the pedal but it WILL PULL Timing, and we are getting rid of the timing pull and leaving the tcs intact for safety purposes (rain/snow)
Old 02-20-2005, 12:08 AM
Magyver's Avatar
I'm referring to timing.
Old 02-20-2005, 12:17 AM
HumpinSS's Avatar
That was in referece to the person above me
Old 02-20-2005, 03:36 PM
Magyver's Avatar
Well I put in about 8 runs at the track last night and I disable tq mngt for two runs and it didn't do nada. My advice is to leave it alone. Well for MN6 at least.
Old 02-21-2005, 11:19 PM
WS6FirebirdTA00's Avatar
how do you disable the torque management?
Old 02-21-2005, 11:28 PM
Magyver's Avatar
1: Open your editor, go to Edit>Transmission>Torque Management.
2: Set Abuse Mode Enable False
3: Set Abuse Mode RPM, Abuse Mode TPS and Abuse Mode Speed to 0
Old 02-21-2005, 11:31 PM
ok thats what mine were all set at
