90mm MAF...any such thing????
Seems like it would make sense with a 90mm intake and 90mm TB.
Anyone make it?
I have the Z06 MAF, is that the biggest and best right now?
Anyone make it?
Originally Posted by HumpinSS
pro-m makes one but it costs a little coin
Originally Posted by slow
I would pass on a Pro-m unless you have reached the maximum output of the one you are currently using.
ryan
ryan
-AFR 225 heads
-FAST 90mm intake and 90mm TB
-upgrading cam to a 248/252 113 lsa (from a 242/242 .610/.610 114 lsa)
-TNT 150 shot with a 90mm power ring OR a DP system on the FAST, maybe 200-250 shot with a stand alone fuel cell
So I think the Z06 will be the weak point there because it'll be far surpassed in its ability to flow the air that the motor will demand.
Originally Posted by Pro Mouse
I dont mean to bring up an old post ,But I too have big motor in very near future and I want to get one tooQuickin Did you find any thing out on where to get one?Thanks!
Ryan
Pro-M/Pro-Flow went out of business since this thread was posted.
Ryan
Ryan
It very well may be true, lets hope the quality goes up a little, as there is a need for a speciality maf makes for the high horsepower guys, and blowthrough applications.
However it will be hard when the "calibrated" mafs there is no need for anymore with good tuning software, and OEM/OEM style meters that will support 700+ rwhp
Ryan
Ryan
I've been told I could let this out of the bag. A member on LS2.com is a partial owner of Professional Mass Air Systems and they're back open for business. They can handle all recalibrations, but new MAFs need to go through their dealers.
Guys dont forget whatever size maf you get the stock ECM wont read more than 512g/sec. Anything serious over stock displacement should just run speed density, save you money and remove the restriction of airflow. Its limited to 512g/sec, SD mode has no limit. Well I think its like 4096g/sec or something.
