Lean AFR for MPG
Lean AFR for MPG
Ok for some of us without lean cruise (us car, non-us have lean cruise) Would it hurt the motor to maybe set air-fuel ratio at 15.0 or so on a long trip. I just dont know if running a engine like that would have any benefit on mpg versus lean cruise on non us-cars. I understand lean cruise runs around 15.5 or but changine afr in parameter B3601would that help any or just hurt the engine more? I was even thinking of setting PE a little lower and raising PE afr a little higher. Im not going to be doing WOT runs or anything just strickly for highway trip. Let me know your opinions guys
stock O2 sensors aren't very accurate past stoich so results may not be very accurate... if you forced the car into open loop, you could then use a wideband to lean accurately lean the car out tot he desired AFR
Just curious to save a few bucks but didnt want to hurt the engine. I know some other countries lean cruise is an option but didnt how it quite worked because like you said o2's are not accruate outside of sotich.
Some of us are able to use the "lean cruise" functions of HPtuners..... IIRC 01+ vehicles. I am averaging 27-28mph on a H/C GTO with lean cruise enabled running about 16.5:1 Pretty neat feature. Those table were filled in from holden's lean cruise settings but I backed them off a bit since they run in the low 17:1 range!! Others are getting 30mpg....
There is a way to actually load your .bin file into a hex editor and change some values to enable the lean cruise. I have not been able to obtain these values from anyone yet because it seems they are scared they would be breaking the law. Posting the information is not illegal, preforming it is
This is an interesting thought. I have an older truck that I think could benefit from a lean cruise mode, however I don't think the early pcm's had that feature (88 vintage TBI model).
So, I would have to lock it into open loop mode for lean cruise. Do any of you guys who have the lean cruise mode (aussies) know under what conditions the system goes into that mode ?
The LM-1 has "Narrowband Emmulation" for just this purpose. You can replace your NB sensor with the LM-1 & its wideband sensor. Then, you can program the LM-1 to emmulate the narrowband signal at any AFR you want. 15.0, for example. This way, you can keep stock closed loop operation. It wll not affect open-loop/WOT operation.
With this setup, you can "lean out" for economy, just like we do with aircraft engines.
