A4 to M6 swap PCM question
All, after my swap I can just install a M6 tune from HPtuners instead of getting it reflashed at the dealer, correct?? I already have a m6 tune, so I am thinking I just need to copy my VE table (for my cam) to it and I should be fine, correct?
Not sure I understand what you mean by OS...Are you talking about the same year of car tune?? Or actual OS of the computer?
My car is a 2002 A4 and the M6 tune is from a 2002 also. I was thinking I would just copy my VE tables to it since it is tuned for my cam.
The M6 you posted is a 98-00 VE table and the A4 you posted is a 01-02 VE table. Compare A4 and M6 tables from the same years and you will see that 98-00 A4, M6 VE tables are the same and on 01-02 VE tables, the A4 and M6 tables only differ slightly on the 15 and 20 kPa lines and only at 2K rpms and below.
