wideband question (aem uego)
Old 06-13-2005, 08:38 PM
Blown Ta's Avatar
Default wideband question (aem uego)
just bought a aem uego gauge type wideband kit. will this work ok for my car or do we need a dual channel unit?
also where is the best place to weld the bung for the wideband 02 sensor?
heres the link of the one i got.
thanks.
http://www.aempower.com/pop_product.asp?pid=36
Old 06-15-2005, 06:56 PM
Blown Ta's Avatar
anybody?
Old 06-15-2005, 07:44 PM
OEF_Trooper's Avatar
You can use a Wide Band on any vehicle just about. If you are going to use a one channel unit you want to mount it where it will see both exhaust streams otherwise you will only measure one side. I have a FAST system on my GN and it's in the DP. My friends 8 sec GN is the same without any measuring issues either.
Old 06-15-2005, 07:49 PM
Blown Ta's Avatar
so it will be ok to put the o2 sensor on my y-pipe after the cats?
Old 06-15-2005, 08:10 PM
It shouldn't be an issue at all. The easiest way to tell if it isn't working well is you get lazy readings. An O2 display should always be moving around at part throttle (driving).
Old 06-15-2005, 08:28 PM
Blown Ta's Avatar
this sucks, i was just reading on the aem website, they say put the wideband 02 sensor before the cats. and v8 cars should use a dual channel.
Old 06-15-2005, 08:39 PM
I wouldn't waste your money on a dual channel setup. Wide bands are the ticket for tuning. None of the aftermarket systems (FAST,MOTEC) use dual sensors. Once you get a decent tune done, you should be all set. Don't get all wrapped up in the hype about widebands. Think of all the power these motors can make with just normal O2 sensors and a good tune?
Old 06-15-2005, 09:58 PM
Blown Ta's Avatar
i am gonna try it on one of the rear cat 02 bungs, i have simms on those right now, so the sensors are not used.
thanks for the help.
