another ses code
Old 07-16-2005, 11:32 AM
bolton98TA's Avatar
Question another ses code
the code is P0420 "the PCM has determend that the catalyst system efficiency for bank 1 is below threshold for the current engin opperating conditions."
is it possible for my cat to already gone bad after 2 weeks?
Old 07-16-2005, 12:47 PM
bolton98TA's Avatar
and if it helps any i just replaced my front o2's with rear vett o2's and i ahve a catted Y pipe with stock o2's in the back. and once my ses light came on the car felt a little sluggish.
Old 07-16-2005, 04:21 PM
LoudmouthLT1's Avatar
Front and rear O2s are different. Put the correct ones in.
Old 07-16-2005, 04:33 PM
bolton98TA's Avatar
what? what do i need to put in the rear? evoryone on here has told me to put rear vett. o2's in the front but noone has said anything about the rear o2's.
Old 07-16-2005, 04:38 PM
Frosty's Avatar
You sure about that?
Old 07-16-2005, 04:39 PM
Frosty's Avatar
You're correct. Don't worry about that. I don't know what your exact problem is but the rear vette O2's in the front are fine. I have the same thing. I put stockers in the ORY pipe(for some reason the MAC Ypipe had a bung for the rear O2's). Had no problems.
Old 07-16-2005, 04:58 PM
bolton98TA's Avatar
alright, thanks. what is the best way to diagnose the problem? have it probed?
Old 07-17-2005, 12:20 PM
2001NBMZ28's Avatar
Only thing I can think of is make sure you don't have an exhaust leak near the cat/02, connections good, wires not damaged/hitting the exhaust anywhere. Maybe try switching the rear 02's and see if P0430 for the passenger side shows up???
Old 07-17-2005, 02:51 PM
98Grnz28's Avatar
What 2001nbmz28 just said try that.
Old 07-17-2005, 03:05 PM
bolton98TA's Avatar
im just going to get them deleted. i found a local guy that is on this forum that said he can do it. thanks guys.
