How many people have messed with this table?
My understanding at first glance is that the ETC table your looking at dictates how much the throttle body opens depending upon pedal position. If you wanted 25% pedal position to equate to the TB opening 25%, this is where you would change that. I would leave it factory in the long run. But, that doesn't mean I wouldn't play around with it. You should check and see what happens when you make it completely linear from 0-100%.
I've heard grips from truck owners on how the throttle response feels "sluggish" compared to their old cable throttle bodies. I'm sure this would help alleviate that! Someone needs to do some experimenting!
At first glance I thougt is was pedal % vs. MAP, but the description states BARO. Maybe I'm having a blonde moment, but how does BARO affect pedal/throttle position?
"All Motor 9 Second club member"
It appears to be the Fly by wire TB position table for the newer 2005 type trucks. I sure hope it is an opportunity to tweak the responsiveness of the these turds. It looks promising though. LOL.
Go get'um Jessie
I'll be your ginny pig, but I'm using HPTuners instead of EFIlive. 15.6s stock w/no tune....yet
Go get'um Jessie
Email me, Ill set something up for ya, The table IS as awsome as it looks. It allows you to take complete control of the throttle blade by how much tps you have and kpa, so you Technically could make 50% throttle make 75% throttle blade, ect.. But i just dont know how far the computer would allow before the tac modual shows an error and shuts it down......
Restricted User
Paul
