need advise on what to use to tune my 98 Ls1
I have a 98 LS1 Camaro that I am currently installing a single turbo on. I am aiming for around 800rwhp. What do you guys recommend for tuning that is most affordable and most capable? Thanks for your help.
you have edit and hptuners for a custom tuning for 98 cars at this time. Both can probaly do the job fine, but look into the licensing, and one will be more cost effective, if you have any friends who have a compatible car.
Good luck on tuning a 800rwhp on the 98 comptuer, unless you have way to make the maf read that much airflow, it is not easy to do.
use megasquirt for the fueling and keep stock computer for igntion/auto trans control, use tuners to change ignition as needed. seems to work well for Parish.
parish clipped the leeds to the injectors and wired them to megasquirt, and hooked up the required sensors for megasquirt.
megasquirt runs standalone to the stock computer.
Originally Posted by dnm12
whats the big deal about the 98? why not just get a larger MAF?
The current GM maf comapnies instead create "trickery" maf's that just lean the car out, causing less fuel and more timing. Basically garbage after you have a tune, since all the same can be done correctly with tuning software.
If somebody would build a maf that would support 1000 g/sec, it would be perfect for the FI guys, but nobody builds one to my knowledge.
HP tuners has said they would not support the 98 cars for speed density boost tuning.
Ryan
So do you guys think that hptuners is the best tuner out there? Has anyone modified the maf to support more power? What would be the advantage to using BS3 over megasqirt and hptuners? Thanks for the help
