Computer History Recording?
Old 09-11-2005, 08:27 PM
NC_T/A's Avatar
Default Computer History Recording?
Ok...have a question regarding the computer. How much history and info does it record? Here is my situation. Maybe you guys can help. My 2000 T/A is having a lot of bottom end noise. A lot. My warranty will cover it if the service dept. finds a problem. If not...i'm stuck w/ about a $700 dollar labor bill. My thinking is to leave the motor running w/ the fans unplugged at my shop. When the motor overheats and ruins....which I'm hoping. What all will the computer record. I know w/ my snap-on brick it will show freeze frame data when the light came on. If I erase the codes and data will it clear everything out of the computer??? Or will there be history still stored on it?
Old 09-11-2005, 08:51 PM
2xLS1's Avatar
PCM will shut off the fuel when it overheats well before any damage is done.
Old 09-11-2005, 08:57 PM
NC_T/A's Avatar
well CRAP!!!!! Any ideas?
Old 09-11-2005, 11:20 PM
kidkl's Avatar
If it has alot of bottom end noise (enough that they take it apart) then they obviously think something is wrong so I dont see why you'd have to pay for anything?
Old 09-12-2005, 12:31 AM
Restricted User
EFILive's Avatar
The PCM permanently records the reason(s) for engine shutoff, such as overheating and low oil pressure.
Permanently means stored in non-volatile memory which is not cleared when power is removed.
Regards
Paul
Old 09-13-2005, 01:32 PM
GuitsBoy's Avatar
The computer shuts down the motor when oil pressure is lost?!?
Thats great! But why have i never heard this before??
Old 09-13-2005, 03:27 PM
Restricted User
EFILive's Avatar
Not on an F-body, since the PCM has no oil pressure input.
Regards
Paul
Old 09-13-2005, 03:29 PM
GuitsBoy's Avatar
Regards
Paul
Figured as much. Those vette boys have all the fun.
Old 09-13-2005, 06:26 PM
NC_T/A's Avatar
I know, but there is always that what if factor. I wanna make sure that they find something wrong. It's not the shop it's more the warranty company. Thanks for the info everybody.
Old 09-13-2005, 07:25 PM
TAQuickness's Avatar
why not slip the shop a twenty to help you out?
