tuning problem or mechanical
Old 10-04-2005, 02:05 PM
Recon12thman's Avatar
Default tuning problem or mechanical
Ive been tuning my Z28 its got SLP CAI kit MAF headers and exhaust FAST fuel rails and 42 lb injectors by Lucas but i turn the car on it kicks over really nice and idles good but as soon as i either give it just a little gas or move it to reverse or drive it dies. Am I missin somethin stupid easy mechanically or is it a tuning thing i can do to fix this i have HP tuners. Any help or ideas would be greatly appreciated thanks guys.
Old 10-04-2005, 02:38 PM
vtanju's Avatar
change your injector flow rate which is located in the fuel control menu to 42lb. but remember you have to calculate how much 42lb is in metric terms if your hpt is in metric mode.
also in the idle menu under idle airflow under idle airflow vs ect menu make everything after 68F 15.
and you should be fine
volkan
Old 10-04-2005, 02:44 PM
ok ive already adjusted the injector flow rate vs map, is there any other things i have to tune with the injectors and what are all the numbers for the idle airlfow vs ect that you have
Old 10-04-2005, 02:49 PM
LS1TECH Sponsor
foff667's Avatar
if you'd like send me your file whenn1@comcast.net & I'll take a look...what flow rate are your injectors rated at? 42.5psi or 58psi?
Old 10-04-2005, 02:57 PM
42.5 ok ill send you my file
Old 10-04-2005, 03:04 PM
vtanju's Avatar
i think you should be fine with these numbers:
20,17.5,15,15,15,15,14.52,14.52,14.52,14.52
18.1,15.75,15,15,15,15,13.5,13.5,13.5,13.5
Old 10-04-2005, 04:27 PM
LS1TECH Sponsor
foff667's Avatar
the ifr looks fine...but im confused as to why you'd need an 800 rpm idle in a bolt on automatic car...honestly not sure why its dying on you.
Old 10-04-2005, 04:32 PM
ok i was just settin the idle on the high side to see if i could keep it from dying thats all
is there anything you could thing of
Old 10-04-2005, 06:03 PM
yea these numbers didnt do anything really it still started up nice but as soon as i gave it some gas it died
Old 10-07-2005, 01:59 PM
vtanju's Avatar
can you send me your file so that i can take a look. meanwhile do you have a wideband hooked up? my email (vtanju@email.com)
