V2.0.17 question???
yup, it's always been like that and sounds like it always will... any vehicle they support tuning they support scanning (if you have an OBDII cavalier for example, it'll scan the OBDII generic stuff but not factory specific)
HPT has also indicated that when the Ford/Dodge stuff is released, you'll be able to scan them as well
^^^ are you trying to scan it or tune it?
The scanner should work on any OBDII GM vehicle... but the tuning portion of it will only work for the models you own licenses for
Yeah, I think he meant downloading the BIN file from a 2001, not going to work. But you will be able to see how it is running. If you want to modify the parameters using the Editor, you will need to purchase the required support.
