Fast 90/90?
1. you need money
2.you need to hang out with your friend steve so he can help you perform the swap..
3.you will need to clean your nasty engine compartment
4.you will also need some sweet fast fuel rails to go with the setup
5.i recommend the nick williams tb over the fast one.....damn krammer i didnt think your were a newbie
I re-used my stock fuel rails since I'm not going FI.
I needed to swap out my valley bolts because the intake wouldn't fit on top of the stock bolts.
Using an LS2 TB, but don't think it will work for the F-body.
I got a noticeable improvement over the LS6. I don't know how you F-body guys get under the cowl.
Stalking
Dont worry D-money,he stalks my posts also,I dont know whats wrong with him,back to subject my car is almost ready,I need for u to tune that idle at least,before I can get it to get tuned
I read on redhardsupra's experiments:
THROTTLE BODY
If you have a bigger throttle body (FAST 90, or Nick Williams) you want to multiply your Effective Airflow Area by 48%. (put in 1.48, select the whole row, hit 'multiply')
Where exactly is the Effective Airflow Area table in HP Tuners?
THROTTLE BODY
