please some one help me!!!
Old 02-04-2006, 08:06 PM
MY(LS)won's Avatar
Unhappy please some one help me!!!
ok here is my problem. my car is throwing two codes. i scanned them with my diablosport.
-random multiple spark misfire
-air bank system 2
i talked to the dealer about the first one they said it could be many things.im trying to find out what the most common reason. ive been throwing this one for a while.
the second one i have no idea what the hell the problem is, and is new.
please i have faith that some one on here can solve my problem.
Old 02-04-2006, 08:22 PM
2001NBMZ28's Avatar
Can you post the actual codes? I've had P0300 a couple times at WOT and just deleted it, air system bank 2 might be P1416?
Old 02-04-2006, 08:50 PM
MY(LS)won's Avatar
yaeh those are the codes. that came up.
Old 02-04-2006, 08:58 PM
MY(LS)won's Avatar
how do i fix p1416
Old 02-04-2006, 08:59 PM
MY(LS)won's Avatar
Old 02-04-2006, 09:04 PM
MY(LS)won's Avatar
if i rev to 4-5 if smokes really bad. the smoke is blue, i dont think my rings r bad, it just started smoking n i dont think my valves r bad either. it runs real fine @ idle. even if i get on it it is still strong.
Old 02-04-2006, 09:33 PM
2001NBMZ28's Avatar
OK, one time I threw P0300 was with the car in park, and someone reving the engine just to see how loud it was. But your dealer is right, could be alot of things...plugs...wires... As for P1416 that's most likely just a bad/clogged passenger side air check valve. Easy to replace yourself (PN 12565503) it's the black round valve between the metal air tube coming off the header that connects to the rubber air hose.
Old 02-05-2006, 02:19 AM
MY(LS)won's Avatar
would that explain the **** load of blue smoke that comes out of the exhaust when i rev hard?!!!!!! its never spit out smoke like that b 4.
Old 02-20-2006, 06:21 PM
salem's Avatar
if you give full throtell whats hapend in 5000 rpm in any gear
Old 03-01-2006, 08:04 AM
RobLS1's Avatar
ok so if it clogged how do you clean it or do you have to replace it because i can find one around here so i am trying to clean mine
Old 03-02-2006, 06:28 AM
RobLS1's Avatar
anybody know how
Old 03-02-2006, 07:06 AM
jyeager's Avatar
Your blue smoke means oil. Oil will very often cause misfires (not to mention rampant knock retard). If the oil consumption is new and there was no 'mishap' coinciding with it, then I'd suspect your PCV valve.
As for the check valve problem? I've no clue. Take it off and look it over. If cleaning it seems feasible do so. Otherwise buy new.
