LC-1 issue...suggestions welcome
OK, so I installed the LC-1 today in place of my stock pre-cat O2 sensor. The intent was to be able to log the WB readings with HPT and simulate the NB sensor to keep the PCM happy.
Problem: After installation, idle AFRs are jacked!@!
Car has a slight bog off idle (pretty sure it wasn't there before) and the WB is reading 12.x AFR at idle. Last time I dynoed it, it was reading 14-15 AFR at idle.
Here's what I did:
1) Verified the HPT wideband readings with Innovate's logging sofware, yep those readings are real.
2) Used the factory default settings for the narrowband simulation.
3) Performed a free air calibration
This is idle, AFR is about 2 points below commanded.
This is steady state cruise, AFRs match commanded.
Here's what I did:
