Simple usability question
I was programming an injector table for a friend of mine the other day and ran into an issue. He had gotten the injector table from here and sent it to me via email (text, not a bin file). I tried to copy the values as a whole and paste them into the table but it didn't like that. I ended up copying and pasting each value into the corresponding cell and hitting enter. Is there a way to do this? As in for any table that I have some values I've received in a word document or calculated in a spreadsheet, is there a way to copy and paste the whole thing rather than individual cells?
Thanks!
Thanks!
Moderator
Text files don't separate the numbers from spaces, for
cut-and-paste; best to first import text file to Excel,
which will turn the stew into separated chunks. Then
it works cleanly.
it works cleanly.
you could try to copy the text (highlight, ctl + c)
and paste it (ctl +v) in to an excel spreadsheet, sometimes it works, sometimes not...
then if you have the correct amount of rows and columns you can copy and paste that table into HP Tuners - I've done it before
