LS2 402 lean idle
LS2 402 lean idle
How much overlap is too much to tune using factory sensors in closed loop?
AFR225 heads, LSX intake, 90mm TB, 1 7/8 headers w/ 3" duals and an H-pipe.
Why is it so difficult to get an answer on this site sometimes? Seems like if it isn't an appearance mod or contain flow/dyno numbers, nobody can offer any advice.
Being that you're even asking this question, I'd think it's safe to say that you'd be better off with a OLSD tune. Then you'll never have to worry.
Unless you have a very good reason for running O2's and closed loop, then don't.
Restricted User
I don't think the MAF will max at idle. Thanks for the reply, tho.
Originally Posted by white2001s10
There isn't any magic cutoff number for overlap since so many factors play into the oxygen content of the exhaust.
We are going to start completely over with it. The thing I'm having a hard time with is that the oxygen sensors (WB and NB) will never get an accurate picture of what's happening in the CC. How will I know for certain that the engine is getting the proper mixture if I can't get accurate measurements out of the exhaust? Wouldn't even an EGT sensor be slightly skewed with the outside air entering the exhaust port?
Originally Posted by 98Z28CobraKiller
I didnt mean at idle. I meant at WOT. I had a hell of a time with my idle with the MAF on. It is much easier to get idling in SD mode and since you have to disconnect it to get the VE tables dialed in anyways, why not just leave it out? JMHO. It's really up to you.
Originally Posted by TAQuickness
to get accurate readings from you wb, you will need to be in open loop
I think Beau (or Bo?) was the only person to understand my question. I think the idle is actually rich because the 02s are reporting a false lean.
