wher can i find this in HPT
Old 04-20-2006, 11:47 PM
mcamarols1's Avatar
Default wher can i find this in HPT
where do i find where the stoich AFR is in the HPT program????? i started tuning with the program but stoped because im start all over w/ a WB02, so now i have to learn how to do it that way, can anyone help me out?? im having a hard time as it is,
Old 04-21-2006, 12:19 AM
Moderator
jimmyblue's Avatar
Engine > Fuel Control > General Fuel screen, Stoich AFR
field is upper left. But, what do you want to do with it?
Old 04-21-2006, 06:53 PM
mcamarols1's Avatar
its not there, i have an 02 if that helps, i just wanna see where its at, dont i need to change it for wideband tunning???
Old 04-21-2006, 07:01 PM
slow's Avatar
no, the stoich value should only be changed when you are changing fuel, ie if you were going to run C16 and knew the stoich point
it is not needed to be changed for wideband tuning.
Ryan
Old 04-21-2006, 07:09 PM
LS1TECH Sponsor
foff667's Avatar
Old 04-21-2006, 07:35 PM
mcamarols1's Avatar
I Have A Diff Screen, Doesnt Have The Stoich
Old 04-21-2006, 07:42 PM
LS1TECH Sponsor
foff667's Avatar
you probably have the editor set to "basic" change it to standard or advanced & it will majically appear. But since you really have no need to change it they figure for the basic or newbie tuner it doesnt really need to be there
Old 04-23-2006, 07:04 PM
mcamarols1's Avatar
where do i change it
Old 04-23-2006, 07:53 PM
LS1TECH Sponsor
foff667's Avatar
Old 04-23-2006, 09:46 PM
mcamarols1's Avatar
thanx
