my SS wony idle...
Old 05-12-2006, 03:24 AM
LS1ATEU's Avatar
Angry my SS wony idle...
i have a 99 camaro SS with 5.3 heads,536 lift cam with mac headers,and now the car will not idle by itseld and it keeps fouling plugs! whats wrong,can the o2's cause this?
Old 05-12-2006, 03:26 AM
LS1ATEU's Avatar
un can check it out at myspace.com./fast99camaross
Old 05-12-2006, 07:36 AM
Billiumss's Avatar
What are all the mod specs? Auto or M6, Any tuning done?
Old 05-12-2006, 10:54 AM
KVU
KVU's Avatar
unplug a front O2 sensor and open up the throttle blade alot. Your problem will be solved.
Old 05-12-2006, 12:47 PM
SSpdDmon's Avatar
It's probably running too rich and needs a little more air and timing to run/idle.
Old 05-12-2006, 03:02 PM
LS1ATEU's Avatar
Default specs
well it has 5.3 heads,milled .30,5 angle valve job, full ported and polished,2.02 valves,and rev double valve springs, and a 536 lift comp cam,mac mid lengths,ported throttle body, with no pcm tuning..
Old 05-12-2006, 03:04 PM
LS1ATEU's Avatar
so can a programmer advance the timimg or how do u do that?
Old 05-12-2006, 03:41 PM
LS1ATEU's Avatar
why does the sensor have to be unplugged,i think it may be bad anyways,but ill try it,,thanks
ill try anything...
Old 05-12-2006, 03:53 PM
Billiumss's Avatar
What are the complete cam specs?
Auto or M6?
Old 05-12-2006, 03:55 PM
'02 SLP#686's Avatar
Check the engine sen fuse under the hood - 20A
Old 05-12-2006, 04:51 PM
LS1ATEU's Avatar
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/T8PCzqLTQ9U"></param><embed src="http://www.youtube.com/v/T8PCzqLTQ9U" type="application/x-shockwave-flash" width="600" height="350"></embed></object>
here is the vid of it..
Old 05-12-2006, 04:53 PM
LS1ATEU's Avatar
Auto or M6?
M6 with a centerforce dual friction clutch, the cam is a 536 lift, 226/236 dur 110 lobe sep
Old 05-12-2006, 04:57 PM
98turbls1's Avatar
your computer is probably going crazy right now because it doesn't know how much fuel to give it so it's probably dumping the fuel in...
Old 05-12-2006, 05:03 PM
stange567's Avatar
maybe check you vacuum lines???
Old 05-12-2006, 09:24 PM
LS1ATEU's Avatar
i'll check it tonight thanks
Old 05-12-2006, 11:21 PM
jbuckweiser's Avatar
Smile
Sounds to me that your heads are leaking oil into the combustion chambers
and fouling the plugs thru the rocker arm bosses. Did you install them or have
done by an installer.
Also a 110 LSA isn't the easiest to tune. The specs are close to the GM ASA
cam, which needs some TLC.
Old 05-12-2006, 11:38 PM
KVU
KVU's Avatar
ill try anything...
Because your sensors will look alot like your plugs. With carbon buildup they will be reading wrong and cause fueling errors. This will exaggerate the problem. One of your problems is the commanded idle is stock. Did you open up the throttle blade yet? That alone will make a huge difference...
Old 05-13-2006, 02:31 AM
LS1ATEU's Avatar
well when i first put the cam in the car idled fime for about a week and the it started doing that and my oil smell like gas bad,im sure my luck my block is cracked
Old 05-13-2006, 02:33 AM
LS1ATEU's Avatar
Smile
i havent had a chance yet but ill try it first thing in the morning. i hope this works..
thanks
Old 05-13-2006, 12:16 PM
stange567's Avatar
you'll most likely need a tune for the car to idle good
