New Cam safe rev limiter
I have a 00 C5 with a MN6 I am installing the texas speed MS3 cam with PRC dual spring kit. This cam from all the dyno print outs I have seen keeps making power past the 6200 rpm mark. Can I safely rais the rev limiter to 6600? From my research I say yes, I just want a few more yeahs of nehs. What do you guys think its my DD but I most certainly wont be on the rev limiter on a daily basis not even close. Thanks
LS1TECH Sponsor
there is no steadfast answer to this question...there are people that spin their motors to 7000-7200 on a fairly regular basis...how long until something fails? 2 passes? 10 passes? 100 passes? bottom line is you should be fine for a while at 6600 and you'll probably be leaving at least some time on the table setting it that LOW actually, but thats not to say the first time you take it to 6600 it wont break...it all comes down to you gotta pay to play really.
Originally Posted by markp03
to be safe i would get rod bolts....they are going to be what fails if something does.
I have the same cam and spring in my car but it is an A4. My rev limiter is set at 6800, but I shift at 6400. Thankfully I have not had any problems with this setup. Car runs great and I believe the max power on this cam is at 6400 so I don't see any benefit in shifting much higher than that.
question
I had this same question, before I installed my ms3.
After i put it on the dyno and made three runs, the care never made any more power pass 63-64000 rpm mark. So to answer your question I would put it on a dyno and take it 6500 rpm's and see what it does, if it look like it was still climbing before you let off the gas then go a lil higher the next time, If not then stay there.
