HPtuners EIO malfunction/broke?
Old 09-11-2006, 05:59 PM
bowtieman81's Avatar
Default HPtuners EIO malfunction/broke?
OK, I have hptuners with the EIO and I am having trouble with my wideband. I used an LM-1, and I know there is a voltage signal getting to the EIO, but on my scanner it reads a constand 12.5:1 a/f in all cells. Has anybody had this issue?
Old 09-11-2006, 06:07 PM
LS1TECH Sponsor
foff667's Avatar
is it hooked to the right input for the LM-1? Im pretty sure theres a specific slot for it that it needs to be hooked to as well as logged in the table display in the correct spot.
Old 09-11-2006, 06:10 PM
Can you elaborate? Not quite sure what you mean by slot. I have it plugged into the EIO input 1 (white wire), and I just used the standard PID for an LM-1 in the scanner.
Old 09-11-2006, 06:17 PM
LS1TECH Sponsor
foff667's Avatar
yeah i always used input 1 on the eio & input 1 in the table display of the scanner...did you configure your LM1 via the software that came with it?
Old 09-11-2006, 08:19 PM
Ya, I borrowed the LM-1 from a friend. My LC-1 did the same thing, so I am pretty convinced something is wrong with the EIO, just don't know what. I contacted HPtuners a week ago and have not heard back yet.
Old 09-11-2006, 08:25 PM
LS1TECH Sponsor
foff667's Avatar
is there any way you can find someone local to try it on their hptuners or efilive unit? It would suck to be without the hardware for 2 weeks or so and it turn out to just be a software issue your missing somewhere
Old 09-12-2006, 11:55 AM
I will see if I can find somebody. Don't know any guys around here with hptuners off the top of my head.
Old 09-12-2006, 12:19 PM
LS1TECH Sponsor
foff667's Avatar
have you contacted support by any chance?
Old 09-12-2006, 12:48 PM
Closed ex-Sponsor Account
sho-me speed's Avatar
Ground from the LM-1 goes in slot 5 on the EIO the whit wire goes in slot 1. Hook the LM-1 up to your laptop via the serial port and program it to
voltage AF
0 10
5 20
in the advance tab set it to 1/6 and program.
I personally used the above settings on both outputs. Make sure the wideband stored the settings.
In HP tuners add the Wideband PID to the table and select the LM-1 config.
This should fix your problem, as the voltage settings of the wideband more than likely were a very small increment. You can check the output voltage of the wideband with a multimeter if that doesn't solve your problem and make sure that it is sending the correct voltage to the EIO.
Old 09-12-2006, 03:13 PM
GuitsBoy's Avatar
I had that happen to me just last night, but it was stuck right at 11.0:1.
I stopped at a gas station and unplunned the box and all cables and reassembled, also rebooted the laptop. probelm went away. For a moment I thougght I needed to buy a new wideband.
Old 09-12-2006, 03:32 PM
Well, I had dynotune check out my lc-1, and it should be back this week. I will start over and hook it up from scratch and see what happens. If it still does not work then it has to be the EIO.
greatwhitess, your procedure is the same thing I do normally.
