Tunning VE table w/HP tunners
I am very new to this and am trying to figure it out .
My previous attemt netted me+18 LTFT it was running close to commanded AFR at that point . I realized I was doing it wrong then decided to try tunning the ve table first .
I am tunning with NGK widband ,Running at about 14.7 at idle . I then shut of LTFT, forced open loop ,keeped the MAF hooked up because it woun't run with it disabled.and the wideband was pinned at 16.00 the highest it goes .
Basicly took ve error vs. widband table copyed and mutiplied buy % w/paste special then copyed thwe primary Ve table to the secondary table .I made a few changes about 3 logs of light driving and it just keeps having me add to the same spots and the wideband isnt changing much(still pinned at16.00) .I am comanding 12'5 at WOT and 14.7 everywhere else
Am I supposed to continue adding ?The way I am going something dosen't seem right to me I belive I have a stock VE table . I have a 98 SS with a cam ,FAST intake ,LT,30svo injectors . Could I just be that off or am I doning something wrong ?
I have an FM-13 cam
FAST 90/90
SLP LT no cats
borla cat back
SLP lid
180 stat
SPEC 3+ clutch
I am tunning with HP tunners and an AFX widband .
The car was tunned for the cam the changes after that were the fast intake from an LS1 intake
FAST 90/90
SLP LT no cats
borla cat back
SLP lid
180 stat
SPEC 3+ clutch
Senior Member
To tune VE you HAVE to disable the MAF, otherwise youll never get VE right and if you do change it, you wont see it. With the MAF enabled, it will control the fueling and for it to change youll have to change the MAF table.
under 4krpm the MAF and VE are blended. to get rid of fuel trims so far negative or positive just decrease/increase the VE. there are so many ways to skin a cat; there isn't a right way anymore. play with the car and do it however you like. people will argue with me all day long about this....
Well when I disable the MAf the car dosent run although after the changes the car will stay running a bit then die I gess its a bit better thatnks for the info
I having some of the same issues. Unplugged the MAF and car runs like crap. LTFT maxed out at +25. Do I have to reset the fuel trims each time I flash the new VE numbers? They keep coming up at +25 each time I log. Checking for leaks as we speak...
im havn the same problem but i didnt reset the fuel trim is tht y it runs like crap if u dnt reset it? i mean when i first go into sd mode
