I just bought LS6 intake and 28.8 lbs
I'm going to swap my stock ones with these. Do I need to retune my car?
EDIT: I just realized I started this thread in the wrong forum... Mod/Admin, will you move this in an appropriate place?
Edit - I mean you should be alright to drive to the tuner. I would NOT leave it like that permanently because it will throw your fuel trims WAY off, which will effect your WOT fueling quite a bit. After a couple hundred miles you will be pig rich at WOT. Normal driving will be fine because your O2 sensors will compensate for the bigger injector.
