Can anyone tell me what laptop to buy for EFI Live?
Old 01-10-2008, 07:38 AM
Tirefire's Avatar
Default Can anyone tell me what laptop to buy for EFI Live?
Just wondering if anyone knows of a good cheap laptop I can buy that can support EFI Live. I really don't know what EFI Live requires as far as memory and stuff like that. Any help greatly appreciated.
Old 01-10-2008, 07:56 AM
kenp's Avatar
I bought a refurbished Gateway for $500 running XP media. It works fine. You need to look at the EFI site. I know they list minimum cpu and operating requirements.
Old 01-10-2008, 08:06 AM
Tirefire's Avatar
Thanks, I guess I should have done that in the first place.
Old 01-10-2008, 08:24 AM
Bluewire's Avatar
Go to dell refurbished website, you can find some killer deals.
Old 01-10-2008, 09:28 AM
Tirefire's Avatar
I looked on their website and could not find any info on this. I might have missed it altogether.
Old 01-10-2008, 09:50 AM
ssheets's Avatar
From the help menu.
REQUIREMENTS
PC/Laptop
Configuration
Recommended
Minimum1
CPU type
Pentium class CPU (Includes AMD and Cyrix)
CPU speed
800MHz or faster
500MHz
Free2 memory
64Mb or more
32Mb
Free hard disk space 100Mb or more
I/O port4
2 x USB 1.1 or 2.0
USB 1.1
Pointing device
Mouse, trackball, touch pad, etc.
Keyboard
Standard PC keyboard
Screen
Standard PC Screen
Operating System
Win2K, WinXP
Win98, WinMe
PC configurations that are below the recommended configuration may not support the full features of EFILive. For example, a 230MHz Pentium may not be able to update all the gauges on the default dashboard while logging real time data at 10 frames per second. In such cases you can reconfigure EFILive, see Appendix-G How to optimize data logging.
Two USB ports are only required if you are upgrading from FlashScan V1 to FlashScan
Old 01-10-2008, 10:06 AM
Tony @ MPH's Avatar
Hey Techfire,
Good speaking with you earlier today. As we discussed the system requirements are laughable Almost any laptop you can buy and certainly any laptop you can buy new from Dell or Gateway will do.
The Dell $499 special will definitely do but the only reason I don't recommend it is because of Vista.
I strongly recommend anyone using EFILive to use Win XP, as the system requirements are substantially lower and you don't have to deal with the sometimes quirky security protocols that are turned on by default in Vista.
Sadly, my laptop with about 1/8th the computing power and speed with Win XP boots faster than my Vista laptop.
Used is even usually a great route to go as you can certainly pick up a laptop with the minimum EFILive system requirements for no more than a couple hundred bucks.
Old 01-10-2008, 10:18 AM
wait4me's Avatar
http://www.dfsdirectsales.com/ That is a good place to buy refurb dell laptops.
The main thing to look at while buying them is battery life. MANY of the newer cheap laptops have crap batteries in them and dont last very long at all. That is the main thing to look for over many other specs as like everyone says, Efilive will run on just about anything.
Old 01-10-2008, 10:48 AM
ssheets's Avatar
I've got a 12vdc PS for my Dell 610. It plugs into my cig lighter and allows me to datalog a road trip!!!!
Old 01-10-2008, 11:28 AM
wait4me's Avatar
http://forum.efilive.com/showthread....light=inverter
Old 01-10-2008, 01:20 PM
AVB
AVB's Avatar
Might want to consider a permanent carpc with a nice touchscreen.
Old 01-10-2008, 01:55 PM
ssheets's Avatar
That's southern hemisphere power
Hmmm, I'll have to turn on the Bat Voltage PID
And mine is not an inverter, it's a DC/DC power supply. I could see where an inverter might put noise on the DC bus creating a problem with the filtering sampling????
Quick Reply: Can anyone tell me what laptop to buy for EFI Live?
