EFIlive users please help
im trying to dial in my RAFIG and when i go to apply the filter on my log it keeps telling me its referencing an unselected pid. This is really making me mad. Why is it doing this?? Help is appreciated.
This warning occurs when you are trying to apply a fiter that references an unselected pid.
FWIW rafig only needs a basic filter.
Include all data frames absolute throttle position is equal to 0% and
engine coolant temp is equal to XX deg c
vehicle speed is equal to 0 kph
XX is the value of the cell in B4307 eg 32 deg C. This is to remove any interpolated data for accuracy.
The vehicle speed filter is only necessary if you are trying to do rafig on road instaed of idling up to temp in the driveway.
yes i understand this and that its just a simple filter. What do i need to name it??? I made my log and saved it and then tried to make the filter and then when i go to apply the filter it says filter:XXX references an unselected pid. filter will not be applied. anyone have this porblem??
Either post your log or email it to me at aatsasp@ozemail.com.au along with the filter list you are trying to apply & I will have a look.
Can you show the filter you are trying to apply? I had no issues with that log other than your TP is at minimum 0.4% so you need to do a tps reset. Off that log your rafig corrections are.
20 deg C -1.429421
32 - 2.252563
44 -2.217104
56 -2.539526
68 -2.870014
80 -3.519002
20 deg C -1.429421
32 - 2.252563
44 -2.217104
56 -2.539526
68 -2.870014
80 -3.519002
5.7 ute how the hell did you get the filter to work??? Because no matter what i do its not letting me apply the filter and keeps saying its referencing an unselected pid.
20 deg C -1.429421
32 - 2.252563
44 -2.217104
56 -2.539526
68 -2.870014
80 -3.519002
20 deg C -1.429421
32 - 2.252563
44 -2.217104
56 -2.539526
68 -2.870014
80 -3.519002
That is why I asked you what parameters you were trying to apply in your filter. There must be something in your filter settings that you have not selected a pid for in your log.
