HP Tuners, codes, state inspection
Old 05-10-2008, 10:16 AM
TexasVortexx's Avatar
Arrow HP Tuners, codes, state inspection
I have had mild tuning with hp tuners, there is no ses light and my car will not pass inspection because of po140,po160 and po1133 codes showing in the background. Anyone know how to fully hide these from the texas state inspection software?
tia
Jay
Old 05-10-2008, 10:23 AM
TAQuickness's Avatar
it's illegal to circumvent the TX state inspection process
Old 05-10-2008, 10:35 AM
that was a lot of help
Old 05-10-2008, 10:41 AM
9000th01ss's Avatar
Go west, I don't know if you need to get inspected close to where you live. I lived in TX for 4 months and got inspected and passed with no cats, no AIR, and all the codes deleted. Would that work if you went an hour west and got it inspected there?
Old 05-10-2008, 11:45 AM
ramairJP's Avatar
You can turn the codes off by selecting "3-No error reported" but by leaving the "SES Enable" on. It sounds like the SES enable was just unchecked which won't set a light but will still flag a code. This, of course, should only be done on an off-road only car
Old 05-10-2008, 12:30 PM
I think that's what we need to do first JP
Thanks
Old 05-10-2008, 02:19 PM
89 formula350's Avatar
I belive they check the IM ready flags too. which with no test done or failed they won't pass you.
Old 05-10-2008, 04:09 PM
Badguy7's Avatar
Just find a place to get an inspection where they dont check everything. There's always a few lazy ppl out there, that dont wanna bother with a full inspection.
Old 05-10-2008, 04:24 PM
slow's Avatar
OBD2 inspection, will check for codes.
YOu will want to check for codes, and readyness tests before you go, you can do that with hpt i believe.
Old 05-11-2008, 02:04 AM
FrankSS's Avatar
hey if you go out to the west of houston...ie austin, washington county, you can get your car inspected for $12.50 and they done even get the thing close to a computer. the only thing they do is drive it around a little and check all of the normal things that are supposed to work... hope this helps
Old 05-11-2008, 02:05 AM
FrankSS's Avatar
and btw... in those counties it is not required to check the emissions on any vehicle
Old 05-11-2008, 09:01 AM
sroach20's Avatar
it has to be inspected in the county you live in, otherwise everyone would drive out to bfe and get it done.
Old 05-11-2008, 05:18 PM
FrankSS's Avatar
i never had it done in the county i lived in... always in another. and the places out there dont really care what county you live in, and i dont think any police will check the sticker to see what county you got the inspection in
Old 05-11-2008, 07:01 PM
sroach20's Avatar
yeah those shops dont care, its not like they can lose their license and get fined. if you get pulled over by a state trooper, they will check your sticker. someone is going to waste their time and gas driving to the country for an inspection sticker, only to be told they have to do it in their county. dont give bad advice to people on here.
Old 05-11-2008, 08:48 PM
I live in Ellis County South of Dallas where we have the same restrictions now as up North.
Lets get back on topic.
Old 05-12-2008, 12:14 AM
FrankSS's Avatar
im only saying what i did... not what he should be doing... if he wants to try and circumvent the diagnostic then that is a possibility...
Old 05-12-2008, 06:23 PM
9000th01ss's Avatar
Well then if everyones going to **** and moan about giving bad advice on getting a car to pass inspection that can't pass inspection, then the obvious answer is to put whatever you did to it back to stock or fix whatevers wrong with it and pass legally.
Kinda stupid to complain about bad advice when you're trying to get a car to pass illegally don't you think? Put it back to stock or fix it.
Old 05-13-2008, 12:19 AM
ryansm1's Avatar
I am not going to tell you how to get an inspection sticker if your car legally won't pass. As posted, that would be illegal.
However, in the event that you are obsessive-compulsive and don't like knowing that the system-readiness tests are incomplete and like to see "pass" next to every test for your off-road vehicle...
P0131-P0167 - Oxygen sensors
P0400-P0430 - EGR, AIR, and catalysts
P1133-P1156 - Oxygen sensors
P1404-P1416 - EGR and AIR systems
P1441-P1443 - Evaporative purge
Set to "not reported" should show you what you want to see, at least with regards to the tests. Leave the MIL indicator enabled for all of the above. Upon flashing the correct changes to the vehicle, the SRTs should immediately show "Complete." What you do with your newly "completed" vehicle is up to you...
Old 05-13-2008, 10:26 AM
Thank's Ryan
Quick Reply: HP Tuners, codes, state inspection
