Help HPT not working And All Kinds of Codes
Old 07-19-2008, 10:53 PM
Pro Mouse's Avatar
Question Help HPT not working And All Kinds of Codes
My HPT keeps giving me fits is it HPT Interface ,Cords or Cars Computer?Keeps disconnecting and saying no signal to interface.I tried to Copy and Paste Codes but couldnt figure it out.I wrote some of them down...
Restraints-B1000-ECU Malfuction (History) (Immature)
Restraints-B1001-Option Config Error (History)(Immature)
Restraints-U1000-Class 2 communication Malfunction (History)(Immature)
Restraints-U1301-Class2 Short Battery (History)(Immature)
Restraints-U1016-Loss of Class 2 Communication with VCM (History)(Immature)
What do you Guys Think?
Thanks
Old 07-20-2008, 08:15 AM
Pro Mouse's Avatar
anyone Know what I have going on here????
Old 07-20-2008, 10:41 AM
Moderator
jimmyblue's Avatar
It seems like something went out while connected,
to get these kind of bus error codes. Start simple,
like did the fuse pop? Inspect the connector at the
vehicle and cable end for pushed pins? That kind of
thing.
If the car starts and runs you can pretty much figure
it's not the PCM bad but a wiring fault (to include
power and connections).
Old 07-20-2008, 10:58 AM
Pro Mouse's Avatar
I have never Had these kinds of codes before ever and I can't seem to clear them outYou know what is weird Here if I put my HPT interface in my house (air conditioned) HPT will work again.Is maybe Humidity effecting it, moisture getting into my interface?
Old 07-23-2008, 10:56 PM
Pro Mouse's Avatar
Still have these codes and can't clear them.Will they go away?I have never had this with my older HPT vcm scanner
Old 07-24-2008, 12:03 AM
Moderator
jimmyblue's Avatar
Those codes are jibber-jabber off the bus from things
that HPTuners doesn't touch - body control module
and the like. It sees them but it doesn't do anything
with them. The older versions did not report them, it
is just "overcommunicating" now.
If it's not PCM (or ECM and TCM on newer models)
then fuggedaboudit.
Old 07-24-2008, 06:31 AM
Pro Mouse's Avatar
Ok thanks Jimmyblue ,so they will not hurt performance or anything....
Old 07-24-2008, 08:56 PM
ChrisS@sdpc's Avatar
You should be good. Just clear them.
