Bung Hole Placement For Lm1
I'm putting in a set up Hooker long tubes and was wondering where I should place the bung. I figure in the y pipe (off road) but not sure where the best spot is for operating. It's an Lm1 unit.
I have an LM-1 too, so I asked for the passenger side since I have my LM-1 wiring going through the firewall grommet behind the PCM.
Sorry I couldn't be more helpful.
I mentioned that to Nick at ARH about the driver's side running leaner and he didn't seem to think so, or maybe he felt it didn't matter enough to make a difference. Maybe because everyone's car is different. I don't know. He didn't try to steer me to having the WBO2 bung on the driver's side. FWIW.
Exactly, I'd have to run the WBO2 sensor wire across the engine bay to the passenger side (using the grommet hole behind the PCM).
So the idea is 18''s of the collector on the passenger side so I don't have wires everywhere. I was looking at my headers which I am on the verge of getting in the car and I notices a bung was already placed on the outside of the passenger header. Would it be okay to just leave it there or is that to far up the exhaust for a good reading? To hot? I figure the header would be a bad spot.
Moderator
The wideband sensor needs to be far enough
downstream that its temperature is never "set" by
the exhaust gas temp, but by its heater always.
Header collector may be too hot at sustained
high output.
I put mine in the I-pipe at the trailing edge of the
passenger's door, use the weatherstrip to keep
the cable snug and the meter ends up where I
can look at it. Also easy enough to access it for
install / remove, without needing ramps, I can
get right at it.
high output.
get right at it.
So, I should pretty much put in a new one after they Y? Also, when I tune it with the LM1 that far back I should take into account it will actually be a little leaner of a reading.
i just worry about exhaust leaks with the **** muffler clamps i have giving me false readings. Thats why i want to put it in the header collector right across from the stock o2. Is that a Bad idea?
high output.
get right at it.
high output.
get right at it.
