Where to buy new drls'/turn sigs?
Old 08-07-2010, 10:13 AM
GSus's Avatar
Default Where to buy new drls'/turn sigs?
Can someone link me a site where to get new QUALITY drl housings?
Mine finally got water logged after the heat cracked them.
Anybody running single filament bulbs minus the drl...turn signal only? If so, bulb number please.
The "new" ones on eBay, any good?
T.I.A
Old 08-07-2010, 11:14 AM
Danny2tek's Avatar
Got mine from ebay... no complaints
Old 08-07-2010, 02:00 PM
GSus's Avatar
Outstanding...I guess they'll all be the same no matter where I get them. Was there anything extra you did to them to prevent them from collecting water?
Still waiting for bulb input...thanks guys
Old 08-07-2010, 03:44 PM
Danny2tek's Avatar
Yep did the !DRL. When the DRL's are on they use bothfilaments which produce alot of heat. You will notice that the heat causes the housing to crack right above the bulb and this is were the water gets in. I've had no issues ever since.
Old 08-07-2010, 09:17 PM
arctic00ws6's Avatar
Not sure how much they are on ebay but I seen them from ws6store.com I believe it was $35? not 100% sure but I know it was cheaper than the $60 the dealer wanted to rape me
Old 08-08-2010, 06:49 AM
GSus's Avatar
Oh ok, been on ws6store several times, I never saw them...in the past. Ill look again, thank you
Old 08-09-2010, 07:13 PM
GSus's Avatar
Got them ordered from ws6store today. Now to research switchbacks so it doesnt happen again.
Thanks to the both of you for the responses.
Old 08-09-2010, 07:54 PM
NP I just went through the same thing less than a month ago ^^
Old 08-09-2010, 09:22 PM
N20zuki's Avatar
Im going to be ordering mine here soon but would like more info on the DRL delete...
Old 08-09-2010, 09:43 PM
Saturn5's Avatar
I just replaced mine with new ones from WS6Store.com and new sockets.
To hopefully prevent it from happening again, I replaced the bulbs with LEDs, which also required swapping in an EL-12 Triton flasher (available anywhere).
I'm not running any LEDs anywhere else because the DRLs are the only ones that have given me any problems. So far, so good. *fingers crossed*
Old 08-10-2010, 01:52 PM
GSus's Avatar
Where'd you get the LEDs? Part numbers? Also, your new socket is the original design, correct?
I replaced my flasher with the el-12 a couple months back already...original was malfunctioning.
Thank you
Old 08-11-2010, 07:44 PM
Saturn5's Avatar
Thank you
Check out: https://ls1tech.com/forums/appearanc...itchbacks.html
I didn't use switchbacks - just regular amber 3157 LEDs, so I didn't have any of the issues he had. EL-12 flasher, new sockets, new DRL housings, and 2 LEDs. Done, and it works exactly the same as factory.
The LEDs I used are similar to the "LED Tower" bulb in his first picture. That's the style you're looking for so they'll shine light in all directions.
There's also a link somewhere on how to change the socket without cutting any wires, but I can't find it right now.
Old 08-12-2010, 03:01 PM
GSus's Avatar
Great, thank you
Old 08-13-2010, 02:59 PM
ShowstoppaTransAm's Avatar
hey i got mine off ebay (price varies but they are top notch) i also went with the two color led (white / amber) which i found on ebay. good luck
Old 08-13-2010, 10:11 PM
GSus's Avatar
Thank you.
Did you have to use a led protecter with them?
I haven't installed my new housings yet, going to tint them soon, then order new bulbs so I don't have to worry about this ever again.
Old 08-18-2010, 12:48 AM
Default parking lights
no been running for a year now no problems
Old 08-18-2010, 02:59 PM
1SLwLS1's Avatar
I know you already purchased yours, but I got both of mine for $65 from the dealer, that was without any of my normal discounts. I didn't have to wait for shipping either. Just FYI for other people coming across this thread.
In case you need new sockets, any parts store with the "HELP!" brand has sockets that work for much cheaper than any of the GM prices. I think I picked mine up for $8/ea. P/N 85881
Old 08-19-2010, 08:27 PM
GSus's Avatar
My switchbacks should be in tomorrow. I went ahead and put my new tinted housings on...freaking looks great. I'm going to go ahead and replace the sockets tomorrow also; the bulbs just fell out by there own weight. So thank you very much for the p/n, was on a/z site last night looking and couldn't find it.
Old 08-19-2010, 08:35 PM
1SLwLS1's Avatar
NP, I assume that you found it on the a/z site with the p/n I gave you, correct?
Old 08-19-2010, 09:11 PM
GSus's Avatar
Haven't looked yet(p/n)...have a/z right down the road, figured I'd just go tomorrow and pick them up. Need to rack up some more reward points w/ them anyway.
