I smell gas
Old 10-27-2012, 07:04 PM
ShaggyLT1's Avatar
Default I smell gas
Hello. I recently bought a 95 Formula m6 from my Navy buddy. He had the car for 17 years. It sat alot the last 3 years. Right after I bought it I put a new fuel filter and Magnaflow cat cause the original cat plugged up on me. The car runs great but I keep smelling fuel. Inside the car and outside near the fuel cap. I looked underneath and see no leaks. Could it be some sort of vent line? Anybody have a similar issue?
Old 10-27-2012, 08:54 PM
Decadence75's Avatar
Does it have cats? If not then it is common to have the smell of unburned fuel.
Old 10-27-2012, 08:57 PM
ShaggyLT1's Avatar
yes. I just installed a new Magnaflow cat and Y pipe. I smell it inside the car too. After its been sitting overnight I still smell it.
Old 10-27-2012, 09:06 PM
weaklt1's Avatar
was a hole cut in the trunk area for a fuel pump change? some guys do the trap door instead of dropping the tank. If a hole was cut and not sealed back up it will smell like fuel.
Old 10-27-2012, 09:22 PM
ShaggyLT1's Avatar
No hole cut. I'm thinking maybe the vent line at the gas cap area. Keep the ideas coming!!
Old 10-28-2012, 05:27 AM
Undertow74's Avatar
Evap purge solenoid might be stuck, not allowing the tank to vent properly
Old 10-28-2012, 07:41 AM
ShaggyLT1's Avatar
Where is and how can I check the evap purge solenoid?
Old 10-28-2012, 03:09 PM
ShaggyLT1's Avatar
I found the top line coming out of purge selenoid which connects near the throttle body was cracked. I temp fixed it with tape and the problem seems to be gone. The smell is nearly gone and when I remove the gas cap I don't get a big release of pressure. Thanks to those who replied!! Now I need to replace the rubber tube and get it fixed right!!
Quick Reply: I smell gas
