common issues and what to look for
Hey everyone, long time forum member just not in this area.I'm looking to purchase 2002 ws6 and was needing to know what common problems should I look for on these vehicles .looking for a black on black ws6 with under 60 miles thanks
If it's an M6 prepare for the clutch master going out at some point. I only mention this because I just replaced mine with a Tick when my clutch pedal stuck to the floor. I had no issues ever since the car was new so I don't think there's anyway to know if it's about to happen but it's a common failure point.
You can check the clutch fluid to make sure it is being changed as it should be clear if it's in good shape. It should be changed like brake fluid should be changed although many never change either until they have problems.
The 10 bolt rear is a problem point on these cars as well. Some people have them last forever and some (like me) have them die an early death. I replaced mine about six or seven years after I bought it new with about 20,000 miles on the car.
Other than the rear end I've never had anything fail (except the clutch master and both window motors) the entire time I've owned it but I service it on a regular basis and keep fluids changed more frequently than suggested.
