2000 trans am side pipes
i was reading threads about some people wanting side pipes on their 4th gen's and of course there were more people calling it a bad idea than that would like them so i fab'd some up for my car and became a member of ls 1 tech to give an idea of what it looks like eventually i will get a camera that can handle the sound so you can also hear it
well now you can never lower the car, because you would drag over anything with those.
Welcome to the site, nice to see someone trying something different, I just think for most it's the ground clearance issue after lowering more then anything else.
I understand wanting the exhaust to come out in front of the back tires, but could the rest of the pipe not get tucked back underneath the car any further? Real issue is there is just not a lot of room underneath these cars for exhaust. Like Daniel said, it is nice to see something different though.
Location: Illinois, as close to "Normal" as I can get...
Now that looks good on both those cars, you said sidepipes and all I could think of was the old chrome hooker styles that run the length of the rocker on the outside
i actually still have about 6 inches of clearance in the center of my car so the 1.5" lowering i was going to do may not end up a problem unless i start driving around orange county and i was also going to get taller tires for the rear to help make the front look lower
the side skirts seam to be taking the heat just fine it has been a few hundred miles with them and still no melting but at that i have the exhaust slightly tucked into the skirts so i had to cut most of the bottom off of them
haha i am thinking chrome pipes running the entire length, but i feel the would need to be bent to resemble the original curve of the rocker and pipe bending is not my forte'
