Power Window
Old 02-04-2008, 07:22 PM
ShowstoppaTransAm's Avatar
Default Power Window
hey my driverside window goes down fine. when i try to put it up it goes half way then it stops. after a few mins it'll go a little more. i have to do this a few times to get it up. is this the motor or something else?
Old 02-04-2008, 10:37 PM
Sunset01TA's Avatar
Motor
Old 02-05-2008, 01:45 AM
Kale's Avatar
Motor. Next time, grab the window and pull while you're hitting the switch. If the motor's REALLY bad, even that won't help. And here's a tip from an owner who's replaced 6 motors now (3 on each side): after you replace the motor, don't roll the window all the way down. You have to sit there and mess with it or wait a long time to get it up again (something about the low-end torque of the rebuilt motors SUCKING ***). And have it replaced by a professional. One cost me $56. Did one myself... 4 hours of pain and frustration is not worth it.
Old 02-05-2008, 02:34 AM
00WSik's Avatar
This is good stuff, cuz i'm having the same problem with my 96' T/A....Motor are only 12 bucks on ebay? are they good??
Old 02-05-2008, 06:42 PM
Kale's Avatar
It's probably rebuilt, and you'll have the same problems as stated above. Usually takes about 8-12 months for a motor to start degrading. It's sooner if you get a badly rebuilt motor.
If I was going to buy from ebay, I'd try to get a new motor instead of refurbished one. You should get twice the life from a no-**** NEW one.
While the door panel is off, you may want to shoot the wires for the motor with a multimeter. This saved me some trouble the last time I had to do a passenger motor; I found out the wire carrying the voltage was frayed and some of the power for the motor was being shorted to the frame ground. Replaced the motor and repaired the wire... been working for about 11 months now, except if I roll it all the way down (gets stuck at the bottom).
Old 02-05-2008, 07:55 PM
RareBreed0295's Avatar
I got one off ebay...no probelms yet. Either a hit or miss for the motors off ebay.
Old 02-05-2008, 08:30 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Here is a tech article on how to replace it
http://shbox.com/page/windowmotor.html
Old 02-06-2008, 12:15 AM
MrElectric03's Avatar
Cool...havent dug into that problem yet on my 96 Z28...thanks guys!
Old 02-06-2008, 12:16 AM
getusumws6's Avatar
autotrix.com has a fix for the window motors for 30 bucks
Old 02-06-2008, 12:20 AM
getusumws6's Avatar
sorry, autotrix.net
Old 02-06-2008, 01:38 AM
00WSik's Avatar
Thanks for the info guys...
Old 02-06-2008, 02:14 AM
Kale's Avatar
Thanks for the Autotrix tip. I'll be doing that next week.
Old 02-06-2008, 05:16 AM
t-rocks firehawk's Avatar
make sure you replace it with rivets not nuts and bolts that come with some motors.
Old 02-06-2008, 06:04 AM
Z28/2002's Avatar
I used the nuts and bolts when I done mine in the CETA and I'm not having any problems
Old 02-07-2008, 04:01 PM
jedimaster71472's Avatar
Same with me. I was surprised how easy it was to change the motor.
Old 02-09-2008, 06:44 AM
they viberate loose over time.
Old 02-11-2008, 11:21 AM
Closed ex-Sponsor Account
autotrix's Avatar
Originally Posted by getusumws6
sorry, autotrix.net
Thanks
how did it go?
Old 02-16-2008, 09:14 PM
MeanWS6's Avatar
This is a feature on our rides
