Pontiac G8 2008-09 & Chevrolet SS 2014+ LSX based RWD 4-door sedans
Money is an object exhaust question
Old 10-28-2010, 11:01 AM
rlwjr1's Avatar
Default Money is an object exhaust question
If I went with a full Solo exhaust or equivalent, how much power am I giving up by NOT going with LTH and using the stock manifolds?? HFC will be used...
Old 10-28-2010, 11:51 AM
Project_Reaper's Avatar
depending on what other mods you have i.e CAI, heads ext. most likely in the range of 8-15hp and 12-18 TQ. the less restriction ( to a point) the better, but headers usually boast alot better #s on the dyno when matched with a CAI and heads.
Old 10-28-2010, 10:01 PM
2QUIK4U's Avatar
If money is the issue I would go with a set of Doug Thorley LT headers. They are about the same cost as the Solo HFC's and will give you about 15-20rwhp more.
Old 10-29-2010, 07:18 AM
pacesetter is a good brand also, if you can swing the extra $75-$100 you can get the nice coated ones but i went cheap and got the painted ones from pacesetter. Great set though alot of low end TQ and pretty cheap.
Old 10-29-2010, 07:25 AM
Devilish34's Avatar
How much will all this cost?
Old 10-29-2010, 09:01 AM
most solo exhaust and catbacks range from $250-$450 depending on brand so an average of $300
Old 10-29-2010, 01:08 PM
Devilish34's Avatar
From Solos site
cat back $795
Hi flow cats $698
So unless I am wrong thats almost $1500
For that much coin I'd buy a Kooks 1 7/8 catted system for $1600+/-
Old 10-29-2010, 01:20 PM
2002_Z28_Six_Speed's Avatar
Originally Posted by Devilish34
From Solos site
cat back $795
Hi flow cats $698
Pretty much the Kooks is the only non X pipe (true dual) and 3'' system so it seems like the right thing to get.
Old 10-29-2010, 02:34 PM
Devilish34's Avatar
my Kooks has an X pipe
Old 10-29-2010, 04:54 PM
Buford's Avatar
mine too.
Old 10-29-2010, 08:30 PM
Wink
From Solos site
cat back $795
Hi flow cats $698
i got my SLP loudmouth bullit 2 cat back for $418 im sure theres better deals out there than $1500 for a cat back. plus i only gave $375 for the pacesetter long tube headers ....
Old 10-30-2010, 12:33 AM
My bad. Would that be an advantage or disadvantage?
Old 10-30-2010, 11:43 AM
2QUIK4U's Avatar
Your SLPs are an axleback not a catback. I paid $1350 for my Kooks headers and x-pipe. It is well worth the cost. The quality and fitment are perfect.
Old 10-30-2010, 11:44 AM
2QUIK4U's Avatar
The x-pipe is an advantage. It helps equalize the pressures between the 2 banks of cylinders.
Old 10-31-2010, 01:46 AM
Thanks!
Old 11-06-2010, 08:48 AM
Wink
Really? im pretty sure when it comes with a 3in offroad Y-pipe with it then its a cat back right?
Old 11-06-2010, 03:59 PM
2QUIK4U's Avatar
If you are talking about SLP's for your Camaro they are a catback but SLP does not offer catbacks for G8's. They only sell axlebacks.
Quick Reply: Money is an object exhaust question
