Pontiac GTO 2004-2006 The Modern Goat
6LE GTO Gauge Overlays
Old 12-31-2010, 09:24 PM
Sommer86's Avatar
Talking 6LE GTO Gauge Overlays
What do you think? We've had these for over a year now but just decided today to post them up to see if there is any interest for the Goat crew.
We've sold over 300 sets for Camaro's.... thought we'd let you in on the fun. Oh, and remember, these are FULLY customizable!
Enjoy....
Stock:
Ours:
Old 12-31-2010, 10:06 PM
6LITEREATER's Avatar
Also, we can make them any color, add any graphic, etc... Just like all of our other overlays Thanks Mike for making me stop procrastinating, lol!
Old 01-07-2011, 06:41 PM
Robofuzz's Avatar
That does look nice! Post up on GasTiresOil.com about them as well.
Old 01-16-2011, 07:59 PM
1INSANEGTO's Avatar
price?
Old 01-17-2011, 01:29 AM
^^Same as all the others... Base is $149.
Old 01-17-2011, 01:30 AM
Sommer86's Avatar
Thanks Robo...DONE!
Old 01-23-2011, 09:37 AM
GT-OH's Avatar
How hard is it to change these out? Also is it possible to make a matching set for the JHP GTO gauges (http://www.jhp.com.au/jhpgto/Interio...GaugePod-h.jpg
http://www.jhp.com.au/jhpgto/Interio...innical2-h.jpg)
Old 01-23-2011, 09:41 AM
sergo's Avatar
not bad and would look pretty sweet with my red needles.
Old 01-23-2011, 10:48 PM
Not a problem at all... We do it for Auto Meters already.
Old 01-24-2011, 12:31 AM
ellies4's Avatar
ignition cyclinder stuck
Old 02-13-2011, 05:30 PM
6.0vette's Avatar
I like them. How bout 7000 rpm redline?
Old 02-13-2011, 05:40 PM
^^No problem.
Old 04-05-2011, 01:37 AM
Sommer86's Avatar
pics fixed!
Old 05-02-2011, 05:02 PM
Sommer86's Avatar
Here are installed pics and an install write up...
Remove the bezel. (remove the 2 screws at the top, and pull it forward carefully.
Don't forget to disconnect the fuel door release
This shows the 2 screws holding in the speedo and the 2 for the bezel. BECAREFUL not to lose the clips these screw into. You'll need these again.
Remember, to get to this step you need to remove the 2 bolts at the bottom of the cluster as well.
This is the wiring harness to the cluster.
This is the clip that powers the cluster. Push the little tab in, and lift the lever. SUPER easy.
Here's a better shot: This is the black lever that pulls up. When it pulls, it releases the connector from the cluster.
These are the gauge trim rings
This is how the speedo looks with the stock face removed. (It's all LED's already)
This is where the LED's shine. The trim ring is on to give you an idea.
Sommer86's Avatar
Here's the backing of the McNord overlays
Here the overlay with the backing removed
Mounting tab on the bottom right
Mounting tab on the bottom left
Overlay laid in place
With trim ring installed - The trim ring just lays in place. There are no snaps or anything else to hold it.
The power clip back in
These are the clips I mentioned earlier. You need these to put the screws in.
Test gauges with power on
Test with lights.
Old 05-02-2011, 05:03 PM
Sommer86's Avatar
Bezel back installed. Dont forget to re-clip the fuel door button
Everything looks perfect!
Old 05-02-2011, 05:59 PM
Sommer86's Avatar
Here's an install video
Old 05-17-2011, 07:46 AM
Robofuzz's Avatar
Nice!!
Old 05-17-2011, 09:56 AM
GreenBlood's Avatar
very cool
Old 05-17-2011, 10:57 AM
impulsegoat's Avatar
Looks good but not enough for 149.99
Quick Reply: 6LE GTO Gauge Overlays
