Project Comments & Discussion Use this forum to discuss Sponsor projects.
W2W 1993 Camaro Build
Old 06-26-2007, 10:23 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Default W2W 1993 Camaro Build
https://ls1tech.com/forums/sponsor-vehicle-projects-shop-tours/616447-w2w-1993-camaro-build-updated-4-25-08-a.html
I'm liking the car and been looking forward to updates. I'm particuarly interested in the rear suspension. You said it was going to be a 4 link car. I was envisioning something completely different. Can you explain how this watts link works, what is involved in installing it, and what the advantages of using a system like this are? I've never seen anything like this before and want to learn more about it.
Old 06-27-2007, 10:06 PM
427's Avatar
It is now a 3 link rear suspension. The 4 link was changed because of the customers needs, drag and roadrace type track days. The 4 link would have bound up the rear end, not allowing body roll. That would be good when he was drag racing but when cornering the car would have wanted to go straight when he pushed it. This system allows body roll and will give him the best compromise so the car can have dual use.
The watts link just centers the car without deflection or side to side motion, even under severe lateral loads when your out on the track trying to be Boris Said! The center pivot is connected to the chassis and rides on bearings sitting vertical in the car. If the links are off you can spin this like a propeller, and it is very smooth on bearings. One link runs above the pivot centerline and one runs below, connecting to the rear axle on fabricated brackets. This is more roadrace type hardware, but we are bringing it to the street. The car will have a quick disconnect front sway bar as well as a quick disconnect rear anti roll bar. By connecting the front bar and adjusting the shocks, cornering will be good. Then unhook the front and connect the back, change shock settings and tires, and you are off to the dragstrip. This is what the customer wanted, a dual purpose car.
Kurt
Old 06-28-2007, 06:46 PM
cbrrmike's Avatar
the level of work you guys put out is absolutely amazing,
the only thing i can think of though is that beating on one of your finished products would be like throwing darts at the mona lisa.........
Old 07-02-2007, 07:36 AM
427's Avatar
Thanks for the good words. I do feel bad about driving hard in a new car thats clean/fresh paint, right up until I start it. Thats when my smile is connected to the gas pedal, and I like to smile!
Kurt
Old 07-06-2007, 01:31 AM
TT-TECH Veteran
Inspector12's Avatar
I loved the attention to detail this car has so far you guys have covered just about everything. Great job.
Jeff
Old 09-19-2007, 08:00 PM
Super Moderator
Reckless's Avatar
Car is looking awesome Kurt....A little bit different than the original plan, but awesome for sure! I bet Jeff is excited to see it coming together. So will he pick it up? Or is it going to spend the winter there and get the new engine and F1?
Old 09-19-2007, 08:36 PM
427's Avatar
Whitey just finished hooking the LT1 to the mufflers, so I think that powertrain is staying in for awhile! The car looks evil sitting on the ground, you would approve I'm sure!!
Kurt
Old 09-20-2007, 01:46 PM
95GreenZ28's Avatar
WOW very nice custom work
Old 09-21-2007, 12:16 PM
427's Avatar
Thanks 95GreenZ28, your name resembles this car!!
Kurt
Old 09-21-2007, 02:36 PM
Sharpe's Avatar
Meh. It's OK, I 'spose. If you're in to that sort of thing.
*dives for cover*
Old 09-21-2007, 09:04 PM
njc.corp's Avatar
very nice
Old 09-21-2007, 09:13 PM
njc.corp's Avatar
Cool
just had a look at the pics and update-
thats top notch work
very very nice-
should go really good-
Old 09-22-2007, 09:29 PM
Fulton 1's Avatar
Old 01-29-2008, 10:29 PM
AnthonyConstant's Avatar
how much is this estimated to cost him?
Old 01-30-2008, 10:15 AM
bad2000z's Avatar
One arm and one leg.
Old 01-30-2008, 10:59 AM
427's Avatar
The car is a ongoing project and would be far from a "budget build", but I don't have numbers as it was done in stages.
Kurt
Old 02-04-2008, 11:08 PM
Fast_94_Z's Avatar
just to do the quarters is about 8000 and that doesnt include the tub work and tin work in the back. it takes about 100 hours according to the body shop manager over there.
Old 02-05-2008, 08:49 AM
landonew's Avatar
Is that it??? That is just about the coolest thing i have seen.
Old 02-16-2008, 01:18 PM
52172's Avatar
thats 8000 well spent in my book those quarters look so bad ***!!! I wish I had the money to do that to my car. I would love a widebody ss. Your car is soooo saawweeeet!
Old 10-08-2008, 03:26 PM
landstuhltaylor's Avatar
Whatever happened to this car?
Quick Reply: W2W 1993 Camaro Build
