383 H/C/I Results!!
Old 01-27-2015, 02:50 PM
SoFla01SSLookinstok's Avatar
Default 383 H/C/I Results!!
4th gen Camaro SS M6
- TSP 383 - GM 5.3L Block
- TSP Forged 4340 LSx 4.00" Crankshaft
- TSP 6.125" Super H-Beam Connecting rods w/ ARP 2000 bolts
- Wiseco -3cc flat tops (11.5:1)ish
- Melling oil pump
- Comp Cams hi tech roller timing chain set-adj.
- Morel 5315 lifters
- Harland Sharp 1.7 roller rockers
- Custom cam spec'd by Martin 235/239 116+2 .637"/.620".
- Racetronix 37lb fuel injectors
- Racetronix fuel pump & hot wire kit
- Fast 92 intake manifold- Mamo ported
- NW 92 T.B.
- Hooker long tube headers 1 3/4 primary(old), Kooks 2" primary 3" collectors(new).
- TSP Rumbler bullet TD's
- PRC 215cc CNC ported cylinder heads 62cc/BTR .660" Platinum springs, Titanium retainers
- ARP crank bolt
- ARP cylinder head bolts
- Z06 MAF (90mm)
- FTP 98 lid
- K&N filter
- Granatelli wires
- GZ vacuum pump (Sportsman)
- ATI Super Damper 7.53"
Chassis:
- UMI solid front & rear sway bars
- UMI 3pt. subframe connectors
- BMR adj. torque arm
- BMR torque arm relocation crossmember
- BMR LCA relocation brackets
- Hotchkis boxed rear lower control arms
- Hotchkis adj. panhard rod
- Spohn LSx tubular solid motor mounts
Drivetrain:
- Mcleod RST twin disc clutch
- Spohn Top Gun driveshaft/ Mark Williams yoke
- Strange 12 bolt 3.42/ TA girdle cover
Attached Thumbnails 383 H/C/I Results!!-camaro.bmp
SoFla01SSLookinstok is offline
Old 01-27-2015, 03:05 PM
HCI2000SS's Avatar
Not bad at all!
HCI2000SS is offline
Old 01-28-2015, 11:06 AM
scotty2000ss's Avatar
Nice! Hows it drive?
scotty2000ss is offline
Old 01-28-2015, 12:49 PM
MYSTIC-1SC's Avatar
Congrats on the numbers. Should be a fun setup for sure!
MYSTIC-1SC is offline
Old 01-28-2015, 12:53 PM
ragtopz28's Avatar
Great #'s...where in S. FL?? (note to self: beware of 01 red SS)
ragtopz28 is offline
Old 01-28-2015, 02:38 PM
Just got back from driving it for the first time. I'm going to have to get used to the idle a bit. I stalled it twice but it's really not that bad at all. Even with the solid motor mounts. It seemed to give a light buck/surge only if lower than maybe 1300 rpm.
Thanks man.
Lol. I'm in north Broward.
Old 01-28-2015, 02:42 PM
conan's Avatar
Nice #'s, congrats.
conan is offline
Old 01-28-2015, 03:37 PM
thunderstruck507's Avatar
Seems like a very abnormal HP peak RPM
thunderstruck507 is offline
Old 01-28-2015, 07:06 PM
sbf
sbf's Avatar
very good power for a mid size cam enjoy
sbf is offline
Old 01-28-2015, 10:24 PM
dkota1968's Avatar
I have a very similar set up crated up on its way. It does have a fully ported fast 90 and im ordering 1 7/8 headers so ill post up. Great numbers should be fun as hell! The low rpm peak should be great for the street.
dkota1968 is offline
Old 01-29-2015, 10:22 AM
Originally Posted by conan
Nice #'s, congrats.
Thanks guys!
I looked into it a bit. It seems to peak a little early. About 5850?. I'm really not worried though. The hp curve seems to flatten out after the peak. Maybe 1 7/8 headers will help the curve on the top end? I am really happy with the entire hp/tq curve. How right before the tq starts to fall off the hp takes over.
Awesome! I'll be keeping an eye out to see your results. Good to check up on similar setups. Thanks man.
I drove her around last night some. She pulls hard! What I noticed, & is bothering me a bit, is how the idle will stay up around 2000 rpm until I get to a complete stop. Then it drops to the proper idle speed. If it was 1k rpm it would be fine. I'll have to get it calibrated right. Some IAC setting? No biggie.
Old 01-30-2015, 07:23 AM
ddnspider's Avatar
Nice setup, I wouldn't worry about the cam peaking early. It's a 383 and you only have 5* of overlap so its not going to be a high RPM screamer. My 383 peaked somewhere in there too. Area under the curve is what makes a fun street car. I also noticed you had it tuned elsewhere this time, good call
ddnspider is offline
Old 01-30-2015, 02:11 PM
Hey ddnspider! I told Martin I was only going to be revving to 6500 max. I am very happy with the cam from idle to the power curve. From all of the others on here, with their experiences, I knew I could trust him for my cam.
Thanks to you, for that little kick in the butt, I needed, I figured I would take my business elsewhere. I'm not blaming them or holding any grudges. Some bad things happening on my last few experiences. Redline Motorsports did the entire short block swap. I was very happy with the detail of the work & procedure. Everything from degreeing the camshaft to checking specifics/tolerances & adding pieces to the puzzle.
Thanks again man.
Old 01-30-2015, 03:09 PM
ddnspider's Avatar
Cool, glad it worked out for you. After your other thread I had pm's saying they had trouble with the other vendor too. I've heard good things about Redline Motorsports so sounds like you should be in good shape. Now get it to a track and have some fun.
Old 01-30-2015, 04:17 PM
Lol. I can't wait to experience the full potential. She's strong! Wish I had her back to make the 1/2 mile event in Ocala.
Old 01-30-2015, 10:20 PM
64post's Avatar
That's a very impressive set of numbers for sure. Do you now what the total ignition timing and A/F ratio was when you made that pull?
64post is offline
Old 01-30-2015, 11:23 PM
Thanks man. Not sure on the ignition timing. I'll try to find out. The A/F ratio is on the graph. Looks to be right around 13:1.
Old 02-03-2015, 01:44 PM
Sales@Tick's Avatar
Torque curve looks great and power curve is just as expected.
Great job on putting together a well rounded combination!
Sales@Tick is offline
Old 02-03-2015, 03:55 PM
Thanks Martin!
It was definitely the right choice to contact you for the cam.
Old 02-07-2015, 08:58 AM
dmiz0420's Avatar
Nice build!
When you look at the headers, a scavenging merge collector like LG pro or Kooks with the merge spike collector, any number of good ones out there.
dmiz0420 is offline
Quick Reply: 383 H/C/I Results!!
