Damn, Think My Clutch Is Done
Old 07-26-2016, 06:01 PM
Hardcoresoldier's Avatar
Default Damn, Think My Clutch Is Done
So I am tearing the 'vette down to put twins on it and refresh the engine while I am at it. When I pulled the clutch, my heart sank a little...Going to clean it up a little better and give it a good inspection, but I think it may be time to replace it. It holds strong and never slipped on me, but it might just be a matter of time...What do you think?
Old 07-26-2016, 07:25 PM
BALLSS's Avatar
FW & PP don't look bad. Hard to tell by the pic of the disc. If the rivets are about at the surface of the pucs...than it is almost worn out.
Given it is a 6 puc disc clutch, doesn't look like it ate up the PP or FW bad. Hit those with some emery cloth
looks like a Monster clutch...ping SNL on this site
Old 07-26-2016, 07:31 PM
yea, it's a Monster Level 3. Judging by the wear on the pucs, the inner half of the puc friction material is catching more than the outer half.
Old 07-26-2016, 07:32 PM
Looking at a Monster LT1-SC since I am shooting for around 1,000ish rwhp with the TT build. Need one that will be friendly as a DD and won't melt down at the track and will actually take the abuse without wearing out right away.
Old 07-26-2016, 08:03 PM
Darth_V8r's Avatar
Received 1,836 Likes on 1,145 Posts
I recommend RPS. You'll pay for it. But only once
Old 07-26-2016, 08:12 PM
No way i could budget 2500 every few years for a clutch. Not now anyway lol.
Old 07-26-2016, 11:51 PM
BALLSS's Avatar
if you are anywhere near that "RWHP" you need a multi disc clutch....maybe even a 3 disc.
Old 07-27-2016, 12:29 AM
Exidous's Avatar
The RPS is only $2500 the first time. Rebuilds are less than half that but the last a lot longer that other clutches that hold the same power. At least that's what I've gathered from others experience. I have and LT1-S and it's a great clutch just heavy even with the lighter flywheel. Just a note. You cannot use ARP flywheel bolts with the LT1 clutches. They are too tall.
Plus with the RPS, you don't have to get the carbon carbon version. Single sided carbon is a bit cheaper just not as nice.
Old 07-27-2016, 07:09 AM
The LT1-SC is a twin disc. And if I can't hit 1,000rwhp with twin Precision 6766 CEAs I will burn the car down bahaha.
Old 07-27-2016, 07:13 AM
I was just on their website, the only one they list as being rated to over 1,000 is $3,300.....no damn way lol.
Old 07-27-2016, 10:25 AM
SNLPerformance's Avatar
Whats the overall thickness of the disc?
Old 07-27-2016, 11:00 AM
Darth_V8r's Avatar
you only have to buy it once. After that it's $400 to rebuild if you ever even need to. The friction material is carbon fiber
Old 07-27-2016, 11:21 AM
A SC is less than $1200 and is rebuildable as well, no need to spend the money when you don't have to.
Let us know the thickness of that disc and we'll go from there.
Old 07-27-2016, 11:24 AM
kingtal0n's Avatar
Time to go automatic 4L80E I guess
Old 07-27-2016, 03:22 PM
lol that is 12k in parts....not gonna happen for my daily. I could put a 5.3 with a built glide and aftermarket ECM and a good portion of the turbo kit in my Vega for that much.
Old 07-27-2016, 03:25 PM
The thickness is between 0.284 - 0.294 measuring from the outside of the friction surface on 1 side to the outside of the friction surface of the other.
Old 08-04-2016, 06:03 PM
Centerforce's Avatar
We would agree. Definitely some uneven wear happening there.
Our DYAD dual disk sound like it would be what you're looking for. It drives just like a stock clutch around town and rated up to 1300 crank ft/lbs. You can scoop the entire kit with clutch, flywheel, hardware, and bearings for about $1700. If you happen to have any questions about it, feel free to shoot us a PM!
Old 08-05-2016, 02:36 PM
https://ls1tech.com/forums/forced-in...l#post19342220
He already bought a clutch, rated for more power, and he spent less.......
Old 05-17-2018, 10:42 PM
frojoe's Avatar
This is so cool.. nice progress, keep it coming!
Quick Reply: Damn, Think My Clutch Is Done
