New Item: Strano Performance Parts Master Cylinder Brace for all 93-02 cars
I'm very proud of this little item, and when I first ran it, I was blown away just how much better it made the brakes!
Here's the link: http://www.stranoparts.com/partdetai...=269&ModelID=7
I have both Red and Black in stock, ready to go on Monday. The pictures attached show only the red as that shows up much better in pictures. We will have other pictures coming too.
Bottom line, if you want stronger brakes and a firmer pedal, this is a part you can't ignore. The flex in the stock firewall is a huge amount more than the flex in stock brake lines, and many of you have replaced those at a higher price than the cost of this part.
I quickly took a before/after video on this. We are editing it into one with some captions but for the time being, I wanted to get the out in front of you guys.
Video comparing before and after:
__________________
www.stranoparts.com --814-849-3450
Results matter. Talk is cheap. We are miles beyond the success anyone else has had with the 4th gens, and C5, C6, C7 Corvettes,
10 SCCA Solo National Championships, 2008 Driver of they Year, 2012 Driver of Eminence
13 SCCA Pro Solo Nationals Championships
2023 UMI King of the Mountain Champion
Coppertone (04-17-2020)
Sam.....so without that brace like my car has been for 19 years.....what is adding the brace going to do for me behind the wheel....?
Is it just going to feel like a good air bleeding was just done....so the brake pedal will just be more firm when pushed?
Because normal driving the brake pedal is hardly pushed at all to stop during street driving. Its just lightly pushed to stop.
Or is this for road racing with hard braking?
Neat. I'll probably be getting one of these.
According to the description on his site:
We include a spacer plate for use on cars that are not running a front mount Shock Tower Brace. We made this modular to work with or without a brace.
I made this contraption several months ago out of sheet metal I had laying around. Bolted it to the studs on the booster and used the shock tower bolts. I should have painted it before hand but oh well. It's hard to see it but the brace goes underneath the master cylinder to the other stud. It's not sandwiched under the master cylinder. It's kind of a pain to get it in and out of there, but worth it because you don't feel the firewall flexing when you step on the brake. Makes the car feel slightly less "GM cheap". For what this thing cost me (nothing) and result I got, I can't see paying $100 for Sam's. Sorry.
Really surprised me when I stripped my shell how flimsy that firewall is. I thought I was chasing air in the lines at nationals but after checking everything over I think most of it was due to the firewall flexing. Just a very soft initial pedal that really came through on the stickers.
Mark this thread.
__________________
Now. This is cheaper than a set of SS brake lines. Hell, it's cheaper than set of decent pads. And this won't wear out.
__________________
No it's way beyond what a good bleed feels like. Just look at how much the MC moves. It's a hydraulic system, and you can bleed it forever, have every bit of air out of it, but like stepping in mud, or sand, when there isn't a solid base your foot sinks.
If you want firmer brakes, then you want this part. If you don't, well then you can skip it. But the firewall can and does oil-can and they have torn with time.
__________________
No. It works with or without. For those that don't have them, there is a spacer plate that comes with the brace that you need to run on the car. Just bolts on.
__________________
However, compare what you have there to what I did. I didn't use that kind of thin metal. It's coated (and lots of folks want that). It installs without removing the Master cylinder.
And well, folks pay far more for things that do far less.
A bunch are leaving today, more as I type this. For those folks getting them, please report back on your thoughts.
__________________
