5.3L Swap Into 1969 C10
5.3L / 4L60E into 1969 Chevy Pickup.
I helped out with the wiring harness and PCM programming on this truck, thought I'd share some pictures. The project turned out very nice.
Battery has been relocated to drivers side for air filter fitment, also, PCM is mounted below the battery tray, to hide it.
A/C Compressor fits with very small notch to frame.
![](http://www.lt1swap.com/pictures/kelly_69_side1.jpg)
![](http://www.lt1swap.com/pictures/kelly_69_side2.jpg)
![](http://www.lt1swap.com/pictures/kelly_69_side3.jpg)
![](http://www.lt1swap.com/pictures/kelly_69_engine1.jpg)
![](http://www.lt1swap.com/pictures/kelly_69_engine2.jpg)
![](http://www.lt1swap.com/pictures/kelly_69_engine3.jpg)
![](http://www.lt1swap.com/pictures/kelly_69_ac2.jpg)
![](http://www.lt1swap.com/pictures/kelly_69_ac1.jpg)
Danny R (08-11-2019)
I've had a few emails with questions, I'll answer a few here.
Headers are a used set of BBK Mustang 79-93 Fox Body headers with the ford flange chopped off, and a LSx Gen III flange welded on.
Mounts are Transdapt type for LSx into factory V8 chassie
Radiator and shroud are factory for the 69 C10, the stock 5.3 fan fits perfectly inside the shroud.
Air intake is the same kit K&N sells for a 99+ truck with a 4.8, 5.3, 6.0
Originally Posted by IOwnCalculus
The pics don't seem to make it too clear - are those longtube headers?
If so, I think I know what I'm getting the truck for Christmas![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
No, they are shorty's
Any old ford header will work, as long as it clears frame and transmission. Here's a ford truck header up to the LSX heads. This should be good news for people with LSx's in mustangs.
![](http://www.lt1swap.com/vortec6000/fordhedder.jpg)
Here's the first set I made. The guy with the truck above made his same way I made mine.
![](http://www.lt1swap.com/vortec6000/drivers_header.jpg)
![](http://www.lt1swap.com/vortec6000/passanger_header.jpg)
Another set I made, well one of them.
![](http://www.lt1swap.com/pictures/53engine.jpg)
Just wondering if you could give just alittle more info on the headers...
1. where did you get the flanges from?
2. how did you un-rectangle the header pipes near the ford flange. In the pictures you can hardly tell they wern't round originaly.
Graham
Graham
Headers are a Mustang 1979-1993 factory replacement , they would bolt in place of factory header.
To open up the ports, I used a torch to heat up the ports red hot, and I used a peice of round steel stock just smaller then the tubes, and drove it into the pipes with a hammer.
The flanges you can find on ebay usually. I've seen them as cheap as $25 a set up to $75 a set.
This is an identical set to the ones I used: (this is a completed auction) http://cgi.ebay.com/ebaymotors/MUSTA...QQcmdZViewItem
GMPP sells the flanges, GM Part# 12480130 $22.00 each
Originally Posted by fastrucken
Actually another question. How come your going to a 5.3 from the 6.0 and why not using Megasquirt anymore? (auto trans control?) hopefuly this will be soon remidied by the GPIO board.
I sold the 6.0L about 2 years ago when I needed some cash for closing on my house.
I'm did use Megasquirt on the 5.3L, I ran pure ethanol in it that I made with a home made still. I only ran it on the engine stand with the ethanol. Thats why you see GM DIS coil packs on the engine pics above.
I am running stock PCM now for auto trans control, that and I have the TunerCat OBD2 software to mess around with it. If it wasnt for having that, I'd be using Megasquirt.
Megasquit is going on a Big Block Chevy I'm working on, 489 inch, sold roller motor....still don't know what its going in.
Originally Posted by Indyjc
Nice truck this is my next project. 71-72 shortbed. Are you done with the truck? Tires & wheels?
I think he plans to keep the stock rally wheels.
