Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
best way to make 1000+hp?
Old 01-24-2009, 04:48 PM
capn smokey's Avatar
Default best way to make 1000+hp?
Hey im going to Pcsing to Okinawa for 2yrs and i prolly wont come home at all so ive decided to go ahead and build a serious street car. I want to make at a minimum 900whp and preferably a lil more, I know how to build a drivetrain and chassis to handle this and my budget is around 20k. What i would like to know is what would be the easiest combo to use to hit my hp mark? I know a BBC is best but what cubes and what power adder? I want simplicity and pump gas usage, I was thinking a a 540 with a F1R at about 12-14psi would get me there. What do you guys think? Please chime in if you have built a street BBC to make this kind of power.
Thanks-Jeremy
Old 01-24-2009, 04:56 PM
JUICED96Z's Avatar
A 540 with a F2R Would make 1,200 pretty easy.
Id get a F2R so you have room to grow if you want and don't have to max out the blower.
I know a guy with a 402 LS motor with a F1R and its about maxed out making around 1,000.
Old 01-24-2009, 05:03 PM
In-Zane Moderator
ZONES89RS's Avatar
If you want FI, do FI, if you want nitrous then do nitrous. I would do a 565 with a 300 hit of gas, that would be a bit over 800 FWHP, then a s stage 300(150+150). 1100 hp when both kits are on. More than that honestly, be about 1000 to the ground.
Old 01-24-2009, 05:09 PM
3.8redbird's Avatar
$86,000 632 hemi 2000hp
Old 01-24-2009, 05:13 PM
JUICED96Z's Avatar
True but with the cam and all that you will need it will still be farily radical, he could build a lot more streetable for a car with FI.
Old 01-24-2009, 09:01 PM
In-Zane Moderator
ZONES89RS's Avatar
Bleh...he is my age, we dont worry about that ****.
Old 01-24-2009, 09:03 PM
ulakovic22's Avatar
That's overkill, you can make 1,000+ with a 496 and a direct port kit. When you start talking about 540+ that means a 502 block or aftermarket and that's at least $1,500. The engine is the easy part, most of that 20K will go towards chassis and suspension.
Camaro Jearmy's Avatar
FI is probably the best bet, better then having to spray it. Constant power, and of course the sound....
Old 01-24-2009, 09:08 PM
slammer454's Avatar
this thing is actually a perfect fit for what you want, 1200 HP pump gas it's a hydraulic cam as well.
http://www.stevemorrisracingengines....ne-1200hp.html
check his site, he just broke 2K on pump gas.
Old 01-24-2009, 10:29 PM
elky489's Avatar
I made 800whp with a 406 and a pro race fogger.
on muscle made a tick under 500 whp and was pump gas friendly,on the wire it made 800whp.
Nitrous in that large of quanity is hard on parts,i would say a 500 ish bbc with a turbo or f2r would be the hot setup.
Old 01-25-2009, 10:10 AM
In-Zane Moderator
ZONES89RS's Avatar
Well, running around with over 600 RWHP makes it fun not needing to spray all the time, then you find someone you need 1 kit(150)...then there is the occasional 850 RWHP supra...then the second kit(150) comes into play.
So...that is a 572? Making 1200 93 octane HP? And you can make 1000 FWHP out of a 400 SBC on 93 octane...what a waiste of cubes, that thing should be cranking over 1400 HP.
Old 01-25-2009, 11:00 AM
3.8redbird's Avatar
all depends on the combo
a 400 can beat a 572 is hp numbers
but if built correctly displacement will always win
Old 01-25-2009, 11:43 AM
In-Zane Moderator
ZONES89RS's Avatar
Stock for stock(not that there is a stock 572), and built for built, a 400 has nothing on a 572...except easier to fit into small cars.
Old 01-25-2009, 11:52 AM
JUICED96Z's Avatar
and a 496 with a 300 shot is not overkill? Sorry but a blower will be a lot easier on a motor then that big of a hit.
Old 01-25-2009, 12:17 PM
Ehh I could build a bbc with nicer parts than that one for a lot less than that. What ar some issues I might run into making that kind of power?
Old 01-25-2009, 12:20 PM
What are some issues I will run into making that kind of power with a bbc? I'm tired of supras dominating the highways, I think it would be awesome to shut down a 1000hp supra with a 3rd gen
Old 01-25-2009, 01:07 PM
KCS
Moderator
KCS's Avatar
Go with an aftermarket block. It's not necessary, but the extra advantages are more than worthwhile. Especially the extra headbolts that the aftermarket blocks usually have would help gasket integrity. While you're at it, you could go straight to 570+ci and make the target power that much easier and leave room for much more if you ever get the itch to do so.
We used a GM Bowtie block for 600ci, with Brodix heads, BDS 14-71 roots blower, and twin dominators to make 1150 hp for the powerboats. The cam was around 260-280 degrees, but was all wrong because we gained 25hp across the board by advancing the cam 1 degree. This was on 91 octane and about 10.5psi and never turned over 6300RPM.
Old 01-25-2009, 02:22 PM
In-Zane Moderator
ZONES89RS's Avatar
If you listen to KCS, you will have more fitment issues, a tall deck makes things harder for the headers to work, even raised exhaust port heads change things up.
Buy a 565 ci short block and put some nasty *** AFR heads on it with a huge solid roller will make 850 HP on motor, a small 200 shot sets you over the 1000 HP mark.
Old 01-25-2009, 04:35 PM
I know not to use a tall deck block Zane but why do you think n20 is the way to go? I know I can make the same amount of power either way but I hate having to fill up a bottle all the time and I also want to be able to cruise a low rpms because it will be a T-56 car. Also does anyone know what an F2R costs? I can never seem to find any prices on Prochargers on the net, its like its a secret or something.
Old 01-25-2009, 05:13 PM
KCS
Moderator
KCS's Avatar
I didn't say he HAD to use a tall deck block, I said he could. He doesn't HAVE to go 570+ci, but he could and he wouldn't need a "huge solid roller" to make 1000hp. He could get away with a hydraulic roller and some decent springs which would probably last forever.
I do believe an aftermarket block is almost required for this kind of power.
Quick Reply: best way to make 1000+hp?
