Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
New cam installed, no start
Old 03-14-2009, 10:41 PM
bowtiescottsdale's Avatar
Default New cam installed, no start
I have just installed a 268h comp cam into a 350 sbc, and as the title states... no start.
The cam was installed straight up, also lifters and new springs were installed.
The OEM HEI distributor was replaced with a HEI jegs brand distributor... this is in a 1983 C-10 pick-up, and the old distributor had a 3 prong hook-up in the back of the distributor that the new distributor did not include. Does anyone know what this is for?
The distributor was installed with the rotor toward the #1 plug wire on the cap, and the #1 cylinder at TDC on the compression stroke.
I believe it is getting fuel and spark because it was backfiring through the carb.
I'm assuming my timing is off, but am look for suggestions.
Old 03-14-2009, 11:30 PM
In-Zane Moderator
ZONES89RS's Avatar
If it is popping thru the carb, the timing is out.
Old 03-14-2009, 11:33 PM
that was my thought, i also am thinking i didnt get the #1 cylinder on the compression stroke... what is the best way to get it there?
Old 03-14-2009, 11:47 PM
In-Zane Moderator
ZONES89RS's Avatar
Well, i usually make sure the intake valve in #1 is shutting and spin to TDC. If it is 180* out it will pop thru the exhaust.
Old 03-15-2009, 03:01 PM
STARTED. thanks
Old 03-15-2009, 04:05 PM
In-Zane Moderator
ZONES89RS's Avatar
Great, when we get to hear it?
Old 03-15-2009, 08:51 PM
ill take a video this up coming weekend... im back at school for this week:-)
Old 03-16-2009, 09:35 PM
any idea where i should set initial timing? i set it to 8* BTDC.... if i was to put more timing in it what would i go to?
Also how mucch timing for a 100 shot?
Old 03-16-2009, 09:47 PM
SMALLBLOCKHERO's Avatar
ive used that cam before and i know NA it like 36-37 all in by 3000. we put squeeze on it and cranked 10 degrees out for it. and it was still a tad high. what compression are you running, aluminum heads or iron?. that will dictate it even further.
Old 03-16-2009, 10:19 PM
its the 260hp crate, so i think its like 8.7:1 CR, on iron heads, how do i set total timing, i only know how to set initial using the timing tab, were you at 10*BTDC... to advance timing i assume i go towards 0, and away from zero to pull timing...?
Old 03-17-2009, 12:22 AM
jmd
jmd's Avatar
Also, how did you set your valve lash? Might be overtight.
Old 03-17-2009, 09:09 AM
it runs now jmd, just trying to tune it the best i can, but i waited till the lifters were at the bottom of the cam circle took up 0 lash and then 3 quarters of a turn after that, then rotated the crank till i had done that on all of em... seems to run well.
Old 03-17-2009, 10:04 AM
pancherj's Avatar
The type of HEI Jegs used will determine how much advance you get. There are three catagories of timing:
1)Initial - set at idle with the vacuum advance disconnected and reading your timing tab
2)Mechanical advance - controlled by the distributor. This can only be adjusted by modifying the HEI. The weights and springs control how fast this advance comes on.
3)Vacuum Advance - controlled by the vacuum canister. It adds to the two mentioned above and is a big help for gas mileage and around-town driving.
If you are reading 10* on the timing tab and your HEI allows for 25 more, your total will be 35 (disregarding vacuum). You can check your total by reving the engine and using a timing light with a dial.
Old 03-17-2009, 12:25 PM
thanks pancherj, to the rescue again always helping me out!
Remember a few months ago pancherj, i couldnt diagnose why i could rev above 4k rpms... well it turns out... the TDC mark on the balancer was in the wrong position... the motor was never timed correctly.
so if i am reading 8* on the timing tab and i want to advance the timing, and i move it from 8* BTDC to 4*BTDC... did i advance it?
Old 03-17-2009, 02:09 PM
pancherj's Avatar
Ahh...I do remember that. When you "advance" the timing, you are causing the spark to happen sooner (before the piston reaches top dead center). If you are at 8* and you want to advance it 4* you should then be reading 12* at the balancer. It is confusing because of the terminology (advance, retard, etc), but if you think about it, it will make sense. The flame takes a while to spread out from the sprak plug. In a perfect world, the spark would happen right at TDC and completely burn the mixture in a few degrees after TDC giving you your highest cylinder pressure with your greatest moment arm between the crank and rod.
Old 03-17-2009, 03:41 PM
ahhh ic, makes sense.
Quick Reply: New cam installed, no start
