Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
383 external balance damper
Old 11-24-2009, 02:28 AM
F-Body Lover's Avatar
Default 383 external balance damper
what is the best damper for 383/400 external balance? my engine has Summit damper and Im not comfortable with it I've heard a small damper will let the engine revs fast and large damper will increase the torque is this right? what do you recommend for this set up : 383ci,5.7 rods,flat top pistons with 2 valve reliefs,Brodix track 1 heads,air gap performer rpm intake,Xtreme energy hydraulic roller cam 224/230 (this will be changed in the future) I want this engine to rev very fast and Im not concerned about the performance because after few months I will order a short block
Old 11-24-2009, 02:50 AM
In-Zane Moderator
ZONES89RS's Avatar
Well, a ATI would do the job, or a fluid damper.
Old 11-24-2009, 04:30 AM
can you please recommend me one?
Old 11-24-2009, 04:43 AM
In-Zane Moderator
ZONES89RS's Avatar
http://www.jegs.com/i/ATI/085/917271/10002/-1
http://www.jegs.com/i/Fluidampr/388/620101/10002/-1
http://www.jegs.com/i/TCI/890/870001/10002/-1
Old 11-24-2009, 06:47 AM
which one you used before?
Old 11-24-2009, 06:50 AM
I dont think these will fit a 400 crank,are they? I cant use internal balance damper on external balance crank right?
Old 11-24-2009, 11:48 AM
In-Zane Moderator
ZONES89RS's Avatar
LOL, i was just showing the brand, hold on.....
This is the one i have personally used. Spun all day to 7000.
http://www.jegs.com/i/Fluidampr/388/720111/10002/-1
Old 11-25-2009, 01:40 PM
speedy55's Avatar
I have been using the summit balancer for 15 years and it handles 7600-8200 just fine.
Old 12-04-2009, 10:26 PM
RedGut86's Avatar
Gotta like that!
O/P I'm not so sure you have that right. I can see the smaller balancer letting you pick up power (tq and hp) due to having less mass, if that is the case, than the larger balancer it replaces. However, you will not pick up torque with a large one.
I think you are thinking of the other end of the engine and flywheels. If you put on a heavier flywheel it can "feel" like you have more torque as compared to a lightweight flywheel which is harder to launch and feels "less torquey" as it really is carrying less momentum than the heavier combination. Hopefully that come out in a somewhat clear way.
Quick Reply: 383 external balance damper
