Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
87 caprice t56 conversion
Old 01-25-2010, 12:45 PM
87gen1350's Avatar
Default 87 caprice t56 conversion
ok now i know that they have been doing this conversion in the 91-96 impalas and caprices for a while now and what i am wondering is what is the diference in my 87 caprice and those 91-up cars.. as in would i be able to use the conversion parts available or do i have to start looking into making my own... has anyone here seen it done in an older caprice/impala.. advise.. tips.. coments. are all welcome i want my car to be MY car and its almost there
Old 01-25-2010, 01:08 PM
the_merv's Avatar
Very easy to be done..
You are going to need the complete LT1 T56 Setup..as in Flywheel, Clutch, Pressure Plate, T56, and all the Hydraulics.
Then the next step would be setting everything up..as in getting the Tranny in..we may have to do a custom Cross Member..marking and cutting the Shifter Hole, installing the Pedals and Hydraulics, and wiring up the Reverse Lights and the Reverse Lockout. For that we will have to do a manual switch since there is no computer in your car that will control it like mine does..no biggie though, it will go in good with all the other switches in there..
You have a 700R4 in there if I remember right so the Drive Shaft wont have to be changed..the T56 and 700R4 are the same length.
Next is the Speedo..your choice of cable or electronic. Stock the T56 is electronic, it can be converted to Cable though.
Here is an example of one here..honestly I wouldn't tear up a Tail Shaft Housing like this..but that's just me..
If it was sent to you already done, or you can send the one off of the Tranny to be done(since it will have to come off anyways), that might be a better option.
http://www.jagsthatrun.com/Pages/Par...pp6-3_6-4.html
It depends on which one is cheaper I guess..maybe you can find and electronic speedo..
Let me know what you think, I'll be back in a few months to help..that and I know how you like wiring..
Old 01-25-2010, 01:17 PM
87gen1350's Avatar
well its not going to happen very soon but it will happen down the road so if i can start gathering this simple conversion parts now thats really what i am intrested in i still have to make my bench seat into buckets..fun... and build a center console for my current shifter setup that could be modified for the manual down the road... and wiring isnt a problem its the computers themselves... look at all the wiring extras i have added so far..(i really aught to cleen it up ento a manageable harness)
Old 01-25-2010, 01:29 PM
the_merv's Avatar
Well keep in mind too where the Shifter is located on these things..waaay in the back.
Don't be suprised if it ends up close to the front of the Seats..remember where it was in Reed's truck?
I'm interested to see what Pedals will go in your car for the Clutch..hopefully someone can chime in..
Ya it is a spider web in there..
Old 01-25-2010, 05:00 PM
ici8uup's Avatar
I am not sure but are 79-82 g bodys the same? i got my clutch pedals out of a 82 pontiac parnissian wagon and put them in a 79 monte carlo, I'm thinking theyll work in your car too they were aviable as on option with a 3 on the floor but it'll hook you up with the pedals and good luck finding a set grab the steering the coulum too check every caprice, monte ,gran prix,parnessian,impala, there out there took me three years
Old 01-26-2010, 02:28 AM
87gen1350's Avatar
i dunno if the 82 g-body and the 80's b-body have the same firewall but i will def look into it thx for a direction to go in now for the scavenger hunt
Old 01-29-2010, 01:57 AM
87gen1350's Avatar
so if any body else has any info on this it would be appreciated
Old 02-23-2015, 02:44 AM
Jake77's Avatar
Howdy folks, im new to the forum and have a similar situation. I have an 82 Caprice which just received a 350H.O. swap. Ive always detested the 700R4 (grew up on manuals) especially for towing and driving on snow/ice. Looking to swap in a hydraulic clutch manual trans (possibly TKO 600 or T56).
Since the 87 and 82 Caprice are of he same generation, I figured I would ask what you came up with for pedal linkage setup, master cylinders, etc. I sure would appreciate any input seeing as I have next to no experience and am having someone else do the brunt of the work. (I just need to start getting parts)
Thanks!
Old 02-23-2015, 10:36 AM
Accrdwgnguy's Avatar
http://www.impalassforum.com/vBullet...d.php?t=278060
You can use the F2B kit, you just need to mod it a bit to clear the steering column in a box body. Or if you are creative, you can make your own pedal set, Gerry made a set for his LS7 95 Wagon.
http://95wagon.com/driveline/T56/index.htm
Old 04-07-2015, 04:45 PM
Jake77's Avatar
Thank you, I will check those out
Quick Reply: 87 caprice t56 conversion
