Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
What Are these and Do i need them?
Old 01-17-2006, 06:31 PM
RelentleZ's Avatar
Default What Are these and Do i need them?
Ok so me and my buddy have managed to spare a 94 Z28 for a track car. There tare down is just about through. I have 2 questions for you guys.
1. What is this..? I think it is some sort of emissions control unit. If not let me know. This car when we are done will be a strictly trailer/track car. Can i bypass this unit and elminate it?
and..
2.Is this the ABS unit? If not, what is it? Can it be bypassed and eliminated too?
Old 01-18-2006, 01:24 PM
Strokinit383's Avatar
Not sure what the 1st one is, most likely emmissions. The second one is your brake proportioning valve/ABS. You will definitely need it unless You want to make your own or go manual brakes.
Old 01-19-2006, 09:07 AM
redbandit98's Avatar
first one is a smog pump...
Old 01-22-2006, 02:44 PM
RelentleZ's Avatar
can i delete the smog pump?
Old 01-22-2006, 02:58 PM
why of course
Old 01-22-2006, 03:02 PM
RelentleZ's Avatar
thats what i like to hear. this car we are working on is not going to be uh... street legal so, its going to go.
Old 01-22-2006, 05:12 PM
Red95Formula's Avatar
here is a link for parts to delete your abs.
sjmmanufacturing.com/cam_brk_lt1.html
And yes the first pic is of the air pump for emissions.
Old 01-23-2006, 05:28 PM
RelentleZ's Avatar
The kit to delete it is like $125 if i understood their site correctly. I cant afford that type of dough on a project car. Has anybody ever relocated the ABS unit on their lt1?
Old 01-23-2006, 05:51 PM
You might be able to use a brake prop. valve from a rear disc thirdgen. I believe they are just small aluminum units. Im guessing the threads are probably the same. And youre in luck, i have some pics off of my old 89RS with rear discs. You can find them around for cheap and the threads are probably the same. You might have to reshape the lines a little.
Attached Thumbnails What Are these and Do i need them?-p6080060small.jpg   What Are these and Do i need them?-modified.jpg   What Are these and Do i need them?-modified2.jpg
Quick Reply: What Are these and Do i need them?
