heads cam sbc questions
whats the best power/tq you have seen from a stock piston/rods/crank chevy 350? and also what was the heads/cam/intake/carb/size of headers combo?
That's kind of an open question. Obviously a short block from the mid-seventies onward is going to be at a disadvantage until you get to the early ninety's because of compression.
What kind of pistons? Flat? Dish?
There's a great aftermarket for what you're asking. What do you need this for? Let us know what your plan is and we'll give our best advice...or..Our 2 cents as it's better known as...
You can make 200-600hp...it depends largely on budget and how wild of an engine you want.
It's probably a 8.5:1(76cc chamber head) compression setup with a dished, 4 valve relief piston that you have. A thin gasket and 64cc head will get you to a nice compression ratio.
what kind of budget is tight to you? it varies from person to person, but when i think heads/cam budget i am looking around $1500-$2000 for good heads and possibly roller cam. it all depends on the $.
