Every engine builder should have one of these
Old 06-12-2013, 12:55 PM
LS1Tech Sponsor
saccitycorvette's Avatar
Default Every engine builder should have one of these
AlignIt Tools are used to align the Rear Main and Timing Covers and install the seals!
Whether your a Pro or a Do Your Own Repair kind of guy, here is a simple but very effective tool to help you make
easy work of installing your LS1-2-3-6-7-9- LQ4-LQ9- 5.3-6.0 and all GM v8's from 1997-2013 Timing and Rear Main cover and seals. Works with all LS based engines!
Here is a couple simple but very effective tools to help you make easy work of aligning your Timing and Rear Main Covers. CNC Machined to exact tolerances, the AlignIt tools
get the covers centered perfectly with the crank. The O-ring design makes for a perfect snug fit no matter the temperature that can cause expansion/contraction of engine covers, crank & tools
that will hinder a perfect fit. The O ring design eliminates this problem. After the covers are centered and torqued down, use the AlignIt Tools to install the seals in seconds!
Available in the Pro Series 6061 Aluminum Anodized and the standard PVC Plastic. Both are CNC Machined to exact specs
from Billet materials.
www.saccitycorvette.com/AlignItTools.html
If you're doing a Rear Main Seal or Engine Build, its a good time to start keeping unfiltered oil out of your bearings and lifters! Check these Billet Oil System Improvement parts out!
https://www.saccitycorvette.com/OilS...provement.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 06-12-2013, 07:30 PM
Carter01's Avatar
Very nice!
Old 06-12-2013, 10:37 PM
LS1Tech Sponsor
Thank you Carter!
__________________
Old 06-17-2013, 02:06 PM
Justins00ss's Avatar
Could of used this about 3 months ago!!! Damn it!!! LOL
Old 06-17-2013, 02:46 PM
snipes's Avatar
Nice...Will you guys have a combo kit price soon?
Old 06-19-2013, 12:54 AM
KTK Z28's Avatar
That's quite nifty. Very reasonably priced as well. I could have used this when I did my clutch and cam install. I will keep you in mind. I assume you allow walk ins and pick ups for these tools? (im in the Sacramento area). Best of luck with the sales.
Old 06-19-2013, 12:10 PM
LS1Tech Sponsor
Hi KTK Z28,
When your ready give us a call. (916) 879-0686
Thanks
Christian
__________________
Old 06-20-2013, 12:11 PM
jman54002's Avatar
ordered mine on Tuesday ...
Old 06-21-2013, 01:38 PM
LS1Tech Sponsor
Thank you jman for your business!
Christian
__________________
Old 08-11-2013, 02:04 PM
Royal_GTA's Avatar
subscribed...will be ordering a kit in the near future
Old 08-13-2013, 12:46 PM
LS1Tech Sponsor
Thanks Royal!
__________________
Old 08-13-2013, 04:03 PM
dmracing's Avatar
How about a package deal with all your tools.
Old 08-26-2013, 01:39 PM
LS1Tech Sponsor
Check this out dmracing.
http://www.saccitycorvette.com/Timin...nmenttool.html
__________________
Old 08-29-2013, 04:17 PM
BlueMagicSS's Avatar
Nice... Going to have to order a set this week.
Old 09-20-2013, 03:08 AM
Blackbob's Avatar
Sweet,will order soon !
Old 09-20-2013, 09:45 AM
one fast zo6's Avatar
Old 09-20-2013, 09:47 AM
s14kouki's Avatar
Very nice.
Old 09-20-2013, 03:55 PM
BLP13's Avatar
Very nice!!!
Old 09-27-2013, 10:27 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
Cool I'll have to pick these up!
-Garrett
Old 10-30-2013, 02:20 PM
02SOMWS6's Avatar
ordered the full set today
Quick Reply: Every engine builder should have one of these
